It is currently Fri Nov 20, 2026 3:33 am
 Post subject: Reptile text revisited
PostPosted: Tue Dec 01, 2015 1:01 pm  (#1)
I will be working on a script to create this effect on a text layer. :)
If there is interest i will share the script here.
I included the xcf workspace file to give you an idea how the channels were used with lighting effects.
reptile-text-script_RD.xcf [586.2 KiB]
Downloaded 225 times
Ideally the text bevel should be rounder and i will work on that also.
 Post subject: Re: Reptile text revisited
PostPosted: Tue Dec 01, 2015 3:31 pm  (#2)
That would be cool. I know that I'd be interested.
PostPosted: Tue Dec 01, 2015 3:36 pm  (#3)
Rod, I'm very interested in your nice reptile text script. :) :bigthup :coolthup Thank you Rod.
PostPosted: Tue Dec 01, 2015 7:21 pm  (#4)
From a very old script that still works (surprisingly)
PostPosted: Wed Dec 02, 2015 8:26 am  (#5)
Thanks Issabella you can get the older versions here.
download/file.php?id=6052
I would like to re write these again to include channel selections and effects.Not many peopke realize you can do effects on channels. :)
For instance in the image below i added a 20 and 20 noise-spread and then a 5 x 5 gaus blur to get the Photoshop effect of "Crystalize"
PostPosted: Wed Dec 02, 2015 3:40 pm  (#6)
Hi Graechan - checked out your script and my Taipans loved it ;)
PostPosted: Wed Dec 02, 2015 4:31 pm  (#7)
Here's a few scale patterns that you guys might find useful.
scale patterns.zip [673.75 KiB]
Downloaded 214 times
PostPosted: Sat Dec 05, 2015 5:26 am  (#8)
conbagui wrote:
Very nice Rob. Can you create a script with the tutorial I wrote Reptile skin, about 2 years ago?
Reptile Skin tutorial
Hi Conbagui.
I prefer not to use layerfx-2.8 as it has a slew of problems running in filters from all versions of GIMP. But i will try and script the tutorial using layerfx.py. :bigthup
PostPosted: Sat Dec 05, 2015 6:59 am  (#9)
Here are the results with layerfx.py.
Perhaps you could show me a picture of the layer stack after effect is finished? Give me an idea of where to push the layers for the correct effect. Mine doesn't look quite the same. Of course we have a different type face and gradient but we need to try and make the effect somewhat the same as yours with layerfx-2.8.py.
Thanks!
PostPosted: Sat Dec 05, 2015 7:02 am  (#10)
Wait after viewing your tutorial link i see the stack order. Does this look correct?
cron
