It is currently Fri Nov 20, 2026 2:30 am
 Post subject: Suborean Guard Combat Helmet
PostPosted: Sun Dec 13, 2015 5:31 pm  (#1)
This is a Suborean Guard Combat helmet. It's supposed to be steampunk styled. Critiques would be appreciated thanks.
 Post subject: Re: Suborean Guard Combat Helmet
PostPosted: Sun Dec 13, 2015 6:58 pm  (#2)
I feel it looks alright, but I have nothing to compare it with.
The edges could be a bet more rounded/smooth, or not so angular and maybe something added to the neck area, would help to make it feel more functional.
Perhaps showing part of a zipper or straps along the back part of the neck material?
PostPosted: Mon Dec 14, 2015 7:06 am  (#3)
Thanks for the feedback Wallace :) . Yes I see what you mean about the back of the lower head/neck area, my design does look a bit bizarre there - I like your idea of straps at the back there - thanks :) .
Thanks also for picking me up on how angular it looks, I based the picture upon a blocky 3D model of mine and didn't do a good job of removing the corners.
To give a bit of background, here are my initial sketches for this:
PostPosted: Mon Dec 14, 2015 8:55 am  (#4)
Pretty cool but they are non-human life-forms? No node, mouth or any kind of breathing orifice?
PostPosted: Mon Dec 14, 2015 6:33 pm  (#5)
Heheh thanks for the feedback Ofnuts, they are supposed to be for humanoid (alien elf type) life-forms. The reason that there is no nose or mouth piece in the helmet is because it has a built-in gas mask that vents out at the back of the head (at that strangely protruding piece at the back of the head). I guess I've failed to elaborate very well on my design - apologies.
PostPosted: Mon Dec 14, 2015 8:30 pm  (#6)
Artloader - interesting, I think we should see these alien elf like/humanoid life forms in Dr Who ;)
PostPosted: Tue Dec 15, 2015 2:19 am  (#7)
Nicely done Artloader. I wouldn't want to have to wear one though!
PostPosted: Tue Dec 15, 2015 12:31 pm  (#8)
You sometimes get these kind of masks when you look for "Gimp" in Google images:)
PostPosted: Tue Dec 15, 2015 12:33 pm  (#9)
May I suggest to have a few lines/stitches around mouth/nose/breathing orifice on the mask then (to hint that there is something in the mask) or a widening of the center strip.
PostPosted: Wed Dec 16, 2015 5:16 am  (#10)
Heheh - that's not the genre I'm going for here Ofnuts - I'd just like to make that clear! :lol
And I'm liking your idea of including extra stitching to hint at the built-in gas mask - thanks again Ofnuts :bigthup .
