It is currently Fri Nov 20, 2026 2:31 am
 Post subject: Country Lake Art
PostPosted: Sat Jan 09, 2016 7:11 pm  (#1)
was bored and tried a new painting..
 Post subject: Re: Country Lake Art
PostPosted: Sun Jan 10, 2016 1:03 am  (#2)
:kpix
PostPosted: Sun Jan 10, 2016 1:47 am  (#3)
Nice Rdgracer.
Two little hints:
1-try not to use the same brush for painting trees and bushes
2-give a little bit of "chiaroscuro" : define where you want to suppose the light origin be then put brushes with different luminosity (or use the lightening/darkening tool) .
PostPosted: Sun Jan 10, 2016 1:49 am  (#4)
Nice :bigthup
PostPosted: Sun Jan 10, 2016 5:35 am  (#5)
astonishing
PostPosted: Sun Jan 10, 2016 11:25 am  (#6)
The leaves on the trees could use more depth, they look kinda like blurry blobs as they are now. Still, it looks nice. Good work.
PostPosted: Sun Jan 10, 2016 11:35 am  (#7)
I like the 'impressionistic' look of this, but I do agree that a light source would enhance it as well as a somewhat different brush for the bushes as their leaves would be different than the tree leaves.
PostPosted: Sun Jan 10, 2016 12:55 pm  (#8)
Nice! I love the texture in the foreground mountains.
"Do or do not. There is no try."
Yoda
PostPosted: Sun Jan 10, 2016 1:41 pm  (#9)
Love the reflection. The blue-ish tinge gives it the feel of water. Here are some things you could try (totally up to you, there is no wrong or right in art)
For the reflection:
Play around with is the ripple filter (under Filters --> Distorts --> Ripple...) to displace the perfect reflection (unless that's what you're going for).
Also, you can give it a bit of perspective using the perspective tool and then stretching the bottom corners outwards.
For the trees:
You got the position pretty nice. I would just try adding a dark shadow behind the leaves to give them a bit more volume and then add as much different green colors as you can to break the flat single color.
Lastly for the mountains:
The edges are really sharp so they kind of steal the focus from the reflection. Here you could try a gaussian blur (under Filters --> Blur --> Gaussian Blur)
Keep at it, you've got some real potential :)
PostPosted: Sun Jan 10, 2016 9:35 pm  (#10)
thanks for all the views and comments. i'll take it all in and try and do better on my next one. i only took like 40 to 45 min to do this. and i kinda just started putting down color. wasn't even sure where i was going with it tbh
PostPosted: Sun Jan 10, 2016 11:50 pm  (#11)
i KnOw a Program Where You Can cReAte SamE LooK --> http://www.ne.jp/asahi/mighty/knight/
Pixia
PostPosted: Sun Jan 10, 2016 11:51 pm  (#12)
like in your art rdgracer71
