It is currently Fri Nov 20, 2026 2:30 am
 Post subject: Basalt Island
PostPosted: Sat Jan 16, 2016 5:49 pm  (#1)
I've been trying to learn how to paint rock faces and water - a basalt island loosely based on this reference photo: http://www.gettyimages.co.uk/detail/pho ... /488932907
 Post subject: Re: Basalt Island
PostPosted: Sat Jan 16, 2016 7:39 pm  (#2)
The water is really good, just a wee bit too sharp on the horizon. The rocks are good, too, just seem a bit flat around the edges, but I have no idea how to give them a more 3-D look.
PostPosted: Sat Jan 16, 2016 7:41 pm  (#3)
Looks like a floating Matterhorn. :)
PostPosted: Sun Jan 17, 2016 2:14 am  (#4)
Nice work! The only thing I think could use a little work is making the water looks less solid. Still good job. :D
PostPosted: Sun Jan 17, 2016 6:56 am  (#5)
Excellent painting. Water is difficult to paint and I wouldn't know how to advise you here - just keep up the practice and you will find your own way. Again, you did an excellent job!
PostPosted: Sun Jan 17, 2016 10:31 am  (#6)
@2-ton: Yes I see what you mean about the sharpness of the horizon, there should be some tiny waves, thanks for the feedback :).
@Lylejk: I just googled Matterhorn and I reckon you're right - I might try painting that one day. Thanks for commenting Lylejk :).
@Mokonofan: You mean maybe making the waves a little bit more translucent and adding more white foam maybe? Sounds good. Thanks for the feedback :).
@Erisian: Thank you for the kinds words my friend, I shall indeed press onwards with my artistic journey as I hope you will too :).
