It is currently Fri Nov 20, 2026 2:30 am
 Post subject: Don't touch.
PostPosted: Fri Jan 22, 2016 11:26 pm  (#1)
ref: http://www.fontplay.com/freephotos/seve ... 107-08.jpg
Just trying to break the mesh binge; haven't played with Make Squiggly in a while, so why not. :)
https://www.flickr.com/photos/34520999@ ... 2/sizes/o/
 Post subject: Re: Don't touch.
PostPosted: Sat Jan 23, 2016 1:33 am  (#2)
ref: http://www.fontplay.com/freephotos/fift ... 906-03.jpg
One more before I hit the sack. :)
https://www.flickr.com/photos/34520999@ ... 9/sizes/o/
PostPosted: Sat Jan 23, 2016 6:35 am  (#3)
GOOD!!! I love it this effect is great too. :hi5
PostPosted: Sat Jan 23, 2016 8:39 am  (#4)
lylejk: nice ones! how come my make squiggly-attempts never look this good? i'm sure you have secret ingredients that you're not sharing! :hoh
PostPosted: Sat Jan 23, 2016 9:12 am  (#5)
Start small, run Make Squiggly, then enlarge this result and run erode to squeeze down the widths, separately run Make Squiggly on an enlarged version by itself, also, add some contrast to another enlarged version, and also run Make Squiggly (note, these are three unique runs on original target; not consecutive runs). Then blend the 3 layers together (lighten and/or Screen). Good for starters. I added fractalize to the mix for added chaos. Still, the trick is to use multiple versions and blend. Play with the Make Squiggly sliders too. Unfortunately, due to the heavy embellishments, I won't be doing a tut on this. Hopefully, my hints will be good enough. :)
