It is currently Fri Nov 20, 2026 2:29 am
 Post subject: Still bored
PostPosted: Mon Feb 15, 2016 5:49 pm  (#1)
(click for DA link)
Brain the size of a planet and still bored.
This is a little study of mixing materials. :) Bonus points if you know which famous character the quote is inspired by!
Krita, a few hours. Feedback is welcome as always!
Griatch
 Post subject: Re: Still bored
PostPosted: Mon Feb 15, 2016 5:57 pm  (#2)
Like the render as I enjoy all of yours, Griatch. You said her head's as big as a planet; hate to get on her bad side. lol
PostPosted: Tue Feb 16, 2016 2:14 pm  (#3)
Nice one Griatch. Marvin the paranoid android from The Hitchhiker's guide to the galaxy inspired the quote. The character is very expressive and I like the way you have rendered the metal hands.
PostPosted: Tue Feb 16, 2016 2:26 pm  (#4)
Nice work Griatch!
:kpix
PostPosted: Wed Feb 17, 2016 2:13 am  (#5)
An awesome piece of work Griatch! Did you go this from imagination or reference? The distortion of the features due to the fists is nicely done and I love the range of colours you've used. Also there's an impressive range of brightness values in this. Looking forward to more!
PostPosted: Wed Feb 17, 2016 6:04 am  (#6)
Very nice work.
PostPosted: Wed Feb 17, 2016 2:15 pm  (#7)
Wooo! I love how you shade with more than the skin color itself. That's always been kinda a fear of mine that I will ruin something if I do that. xD
The metal hands throw me off a bit, I think because the joints on the hands are looking right at us as opposed to them showing an edge..That's probably my perception not an actual problem. xD
Great work! She sure looks bored.
PostPosted: Wed Feb 17, 2016 3:37 pm  (#8)
Surprised you are bored. NONE of your paintings are boring. This one is just as good as all your work.
PostPosted: Wed Feb 17, 2016 4:44 pm  (#9)
this reminds me of Ex-machina the main character.
PostPosted: Thu Feb 18, 2016 3:32 am  (#10)
Excellent use of warm and cool colors to create a well-rounded face. Perfect expression.
I installed Krita, but have not had a chance to try it yet. Beautiful results as this demonstrates. But it is not the program that does it!
PostPosted: Fri Feb 19, 2016 6:45 pm  (#11)
Thanks for the comments!
Yeah, wouldn't want to catch her in a "grumpy" mood. ;)
Yes, you are the only one to know (or bother) to figure out the quote. It felt like a fitting reference. I'm glad she comes across as expressive despite being, well, partly metal.
Nice work Griatch!
:kpix
Thanks!
Yes, I worked quite a bit to get the values down; I have started to test out the effects of autoleveling occationally, after recommendations in these forums, and it helps to bring the ranges a little more in order (I do tend to work with pretty stark contrasts overall, so over-saturation can be an issue at times, due to different monitors).
I used a reference for the pose of the hands, but otherwise it's all imagination. :) Glad you like it!
The Warrior wrote:
Very nice work.
Thanks, glad to hear that.
Thanks for the feedback! I've found that one can add quite a lot of other colors to skin; it's often useful to experiment. If you are afraid of ruining things, try it on a separate layer (or a duplicate of your image if you use mixing brushes, like here).
What do you mean by "the joints of the hands", more precisely? The knuckles? Or the joints between the fingers? Could you elaborate on what you mean?
Oh, I'm practically never bored in real life. Way too many things to do. She probably already did them all though. ;) Thanks for the kind comment! :D
The Ex Machina character (cool movie) strikes me as having a more fragile appearance, but sure, I can see where you are coming from. :)
Glad you like the expression, and the use of color - I did for once do the shading in grayscale and colored it afterwards; it's easy to get a rather monochrome result from that, so I spent lots of work to flesh out the color scheme.
Whereas I've worked in GIMP for many, many years, Krita is moving ahead now on the painting side I think (GIMP has stated that from-scratch painters are not the main target audience, so I guess it's not too surprising). I find myself using Krita more and more, mixed with some MyPaint for the pure no-nonsense joy of it. But as you say, all these programs could produce the same result, just with slightly varying workflows.
Griatch
PostPosted: Sat Feb 20, 2016 8:55 am  (#12)
Nice work, I love the colors and her expression.
PostPosted: Sun Feb 21, 2016 7:28 am  (#13)
Thanks glad to hear it. :D
Griatch
