It is currently Fri Nov 20, 2026 2:30 am
 Post subject: Mosaic all done in G'MIC.
PostPosted: Sat Feb 20, 2016 10:47 am  (#1)
ref: http://www.fontplay.com/freephotos/seve ... 406-03.jpg
Used Difference Transformation followed by Make Squiggley to create the block outlines. Used Skeleton to squeeze the lines and Blend (Shape Average) {located under testing in my name; preset that David saved for me} to colorize the blocks. Used Local Orientation to create the relief and yes, a few nuanced steps to get it to look like I wanted to. Still, cool that this mosaic like pattern can be created using G'MIC. :)
 Post subject: Re: Mosaic all done in G'MIC.
PostPosted: Sat Feb 20, 2016 12:33 pm  (#2)
:kpix
PostPosted: Sat Feb 20, 2016 12:40 pm  (#3)
:ditto
PostPosted: Sat Feb 20, 2016 1:00 pm  (#4)
Thanks for the comments. Thought I would do another one. :)
ref: http://www.fontplay.com/freephotos/seve ... 806-02.jpg
https://www.flickr.com/photos/34520999@ ... 6/sizes/o/
PostPosted: Sat Feb 20, 2016 3:05 pm  (#5)
well done Lyle !
PostPosted: Sat Feb 20, 2016 3:20 pm  (#6)
Thanks, Diego. :)
PostPosted: Sat Feb 20, 2016 5:24 pm  (#7)
Very nice, Lyle!. You really do know how to use those filters and colors. Wish I could learn that!
PostPosted: Sat Feb 20, 2016 5:42 pm  (#8)
Thanks Pat; it's all about the play.
Anyway, why not another one. :)
ref: http://www.fontplay.com/freephotos/seve ... 107-08.jpg
