It is currently Fri Nov 20, 2026 12:56 am
 Post subject: Without sphere
PostPosted: Mon Feb 22, 2016 11:51 pm  (#1)
I just ran 'Manhattan' on this picture. Kept the layers and decided to keep it without the sphere.
 Post subject: Re: Without sphere
PostPosted: Tue Feb 23, 2016 12:09 am  (#2)
:kpix Looks like it's going very fast. :bigthup
PostPosted: Tue Feb 23, 2016 12:27 am  (#3)
...which is equivalent to run:
Blur > Motion Blur > Zoom and choose the length you like
in this case only 45
PostPosted: Tue Feb 23, 2016 4:13 am  (#4)
I know Dinasset ;) Btw your rose looks good
Thanks Wallace :)
PostPosted: Tue Feb 23, 2016 4:42 am  (#5)
It doesn't look quite the same to me. Perhaps it is the subject matter, and this is all mental, but the train really does seem to 'move', while the rose looks more like a soft-focus blur.
PostPosted: Tue Feb 23, 2016 6:51 am  (#6)
Thanks steven
