It is currently Fri Nov 20, 2026 12:55 am
 Post subject: Re: Delicious Strawberry text
PostPosted: Sat Feb 27, 2016 2:44 pm  (#1)
Really does look like real strawberries!
 Post subject: Re: Delicious Strawberry text and Dark chocolate syrup tex
PostPosted: Sat Feb 27, 2016 11:03 pm  (#2)
Looks delicious, conbagui. :)
PostPosted: Sun Feb 28, 2016 12:35 am  (#3)
I'd like to give the tutorials a try. The outcomes you have there are awesome.
PostPosted: Sun Feb 28, 2016 3:16 am  (#4)
Conbagui I like that composition a lot. Very attractive result. Thanks for sharing. :bigthup :coolthup
PostPosted: Sun Feb 28, 2016 8:41 am  (#5)
Yes but indeed the syrup should be on the strawberries. :) mmmm. Nicely done. The effect is really good.
PostPosted: Sun Feb 28, 2016 10:27 am  (#6)
I'll repeat it as in step 6 I didn't get the right result. Anyway I enjoy doing it. Thanks Conbagui. :) :tyspin
PostPosted: Sun Feb 28, 2016 12:11 pm  (#7)
Thank you so much ED. I threw it away as I think to repeat it. If I am lost again I'll send you the file. :) :tyspin
PostPosted: Sun Feb 28, 2016 1:21 pm  (#8)
Well, I think that I found the reasons to get a different result. At 6 step when Bevel & Emboss it's necessary to click on "invert"; Then on layer text copies (both) I have to put them at overlay mode after running the effects. Anyway, I have upload the file just in case. Thank you so much ED. I love the result. :hi5
Fresas.xcf.zip [1.57 MiB]
Downloaded 155 times
PostPosted: Sun Feb 28, 2016 3:30 pm  (#9)
and just the missing "sirope". :)
PostPosted: Mon Feb 29, 2016 2:52 am  (#10)
Thank you so much Conbagui, your advice is great help for me. I'll try it again having your useful advice in mind. :) :tyspin
