It is currently Fri Nov 20, 2026 12:56 am
 Post subject: Oreo Mosaic.
PostPosted: Sun Feb 28, 2016 6:54 pm  (#1)
O shared this image and I couldn't help myself. lolol
 Post subject: Re: Oreo Mosaic.
PostPosted: Sun Feb 28, 2016 6:59 pm  (#2)
That looks like a chocolate maze I'd like to be stuck in. :lick
PostPosted: Sun Feb 28, 2016 10:33 pm  (#3)
It's OK, Lyle. We understand. Which method did you use on the Oreo, or did you make up a new one?
PostPosted: Mon Feb 29, 2016 2:16 am  (#4)
excellent Mosaic, a real Roman pavement
PostPosted: Mon Feb 29, 2016 2:57 am  (#5)
This one is perfect too, Lyle. I like specially the soft bright you applied on the mosaic. It's really great! :clap
PostPosted: Mon Feb 29, 2016 5:28 am  (#6)
Yum, Maybe I can eat a cyber one without it affecting me ;) Look nice
PostPosted: Mon Feb 29, 2016 6:51 am  (#7)
That turned out pretty great Lyle! :)
PostPosted: Mon Feb 29, 2016 7:12 am  (#8)
:jumpclap
PostPosted: Mon Feb 29, 2016 8:23 am  (#9)
Thanks all. To Pat, I did modify my flow a bit in that I don't stroke for the dots anymore. I toggle the selection mask, and, with a white brush, stroke it, un-toggle, and fill the resulting selection with black. I then run G'MIC's b/s>dithering to get a cleaner dot. Otherwise, the same flow as before (well, used the original and set to overlay as well as textured it with one of my textures). :)
