It is currently Fri Nov 20, 2026 12:55 am
 Post subject: Desktop Documents Folder Icon
PostPosted: Tue Mar 01, 2016 3:52 pm  (#1)
The folder type image you see below is a Documents Folder Icon ,
I made for my desktop and thought I'd share it with you all.
The image dimensions are 256x256.
Here's an example screenshot I took,
showing how the icon appears on my desktop.
File comment: Zip contains both .icon and .png files.
Documents folder icon and png.zip [43.91 KiB]
Downloaded 280 times
 Post subject: Re: Desktop Documents Folder Icon
PostPosted: Tue Mar 01, 2016 7:00 pm  (#2)
Very nice Wallace, wow, you have a lot of icons on your desktop.
