It is currently Fri Nov 20, 2026 12:56 am
 Post subject: Cherub mosaic.
PostPosted: Tue Mar 01, 2016 4:52 pm  (#1)
ref: http://www.fontplay.com/freephotos/4thf ... 506-14.jpg
Still experimenting. Separated the darks and the lights and created two stroke paths and different distances for the strokes to create the mask this time. Also working at techniques to clean to stones (not happy with what I had to do, but I think this comes close to getting away with this; lol). :)
https://www.flickr.com/photos/34520999@ ... 2/sizes/o/
 Post subject: Re: Cherub mosaic.
PostPosted: Tue Mar 01, 2016 8:47 pm  (#2)
Not having the wherewithal to do the mosaics, I was wondering if any of you experts know if the 'stones' can be brl'd into glass, shiny shiny glass stones or gems?
PostPosted: Tue Mar 01, 2016 9:34 pm  (#3)
You can use whatever texture you want since the borders are transparent. BRL is a great idea, 2-ton. Still, I prefer texturing using patterns. :)
