It is currently Fri Nov 20, 2026 12:57 am
 Post subject: An attempted at Stained Glass.
PostPosted: Fri Mar 11, 2016 8:55 am  (#1)
It's been a while since I last tried. Diego's cool results inspired me to try again. Still not happy. Need to find a cleaner way to generate the solder patterns. :)
 Post subject: Re: An attempted at Stained Glass.
PostPosted: Fri Mar 11, 2016 1:39 pm  (#2)
Still not happy.
I think you're right about the solder pattern Lyle.
PostPosted: Fri Mar 11, 2016 7:26 pm  (#3)
The best way I have found to do stained glass is to duplicate whatever image youre working on and then grow it to about 6 or whatever looks good fill it with black or whatever color you use for the lead
Then by hand, trace whatever lines you want the window/glass to look like
Here is one I did a few years ago
I used the glass and Plastic plugin to color the wings, duplicated and enlarged the wings filled it with black
I think I ran the plastic filter on the lines so it gave it a little dimension
I was happy with the result {at the time)
PostPosted: Fri Mar 11, 2016 8:19 pm  (#4)
Here is another one I did, that has more of a stained glass look to it
although, it doesnt have any panels in it
PostPosted: Fri Mar 11, 2016 9:13 pm  (#5)
Impressive results Norseman143. :)
PostPosted: Sat Mar 12, 2016 2:50 am  (#6)
I like your results, Lyle and Norseman. :) :bigthup
PostPosted: Sat Mar 12, 2016 7:07 pm  (#7)
Thanks Lylejk
I think stained glass is one of the hardest things to achieve and make it look like real stained glass
The ones I posted, look fake, because real stained glass vary and each panel is different from the others
On mine, you can see I repeated using the same pattern, and doesnt look real
The Harley wings were made using the plastic and glass plugin. To Me, it looks more like blown glass, but I really like that plugin, and is one of my favorites
