It is currently Fri Nov 20, 2026 12:56 am
 Post subject: Red Apples Lie - Barfly (updated)
PostPosted: Mon Mar 14, 2016 6:17 pm  (#1)
(click for DA link)
A little study from my Where Red Apples Lie world. The unknown girl is featured before in my gallery, including the comic snippets. This is a particular style I've used consistently with this particular character and story.
It started as a little anatomy study. :) Comments and critique are as always appreciated.
Update: After your feedback I made some changes:
- Fixed anatomically weird thumb
- Shrunk her foot/leg a bit, clarified the shape of her left breast a little
- Made the perspective of the other stool more distinct
- Some more shadows
- Experimented with more depth cues by blurrying the background and stool in the foreground
Lemme know if it's better!
Griatch
 Post subject: Re: Red Apples Lie - Barfly
PostPosted: Mon Mar 14, 2016 6:59 pm  (#2)
I think it looks nice.
Is the thumb of the hand that's holding crutch in the wrong place?
PostPosted: Mon Mar 14, 2016 7:16 pm  (#3)
That's an excellent point - the thumb is indeed in the wrong place! Thanks, I'll fix that.
Griatch
PostPosted: Mon Mar 14, 2016 7:37 pm  (#4)
Griatch
PostPosted: Tue Mar 15, 2016 12:55 am  (#5)
the thumb could be .... a lie itself ! .....
very nice drawing, Griatch
PostPosted: Tue Mar 15, 2016 1:00 am  (#6)
I wanted to play with my last filter (my swan-song)
red_apples_lie___barfly_by_griatch_art-d9v8ssp_stainedglasswindow.jpg [ 1.11 MiB | Viewed 2983 times ]
PostPosted: Tue Mar 15, 2016 7:12 am  (#7)
Very nice Griatch. Look forward to your contributions.
PostPosted: Tue Mar 15, 2016 1:46 pm  (#8)
Griatch wrote:
(click for DA link)
Griatch
OK, she has only one foot so it gets a lot of use, but didn't it grow a bit over-developed? And I can't invoke the same reason for the asymmetry of her breasts :)
Nice picture otherwise :)
PostPosted: Tue Mar 15, 2016 4:56 pm  (#9)
Another nice piece of work Griatch. I like the way you have worked the light and shadows, especially the shadows on the ceiling. I wonder though if her left thigh should be more in shadow? Although maybe not since there seems to be another light source shining downwards onto the floor.
Keep going my friend, looking forward to more from you :).
PostPosted: Wed Mar 16, 2016 1:45 pm  (#10)
Thanks for the comments! I went back and updated this image, while also experimenting with some other features such as more extreme depth-cues from blurrying (which also makes the rather simplistic background less prevalent). Lemme know what you think!
@Wallace
Fixed the thumb to make the hand more anatomically correct. ;)
@dinasset
Who knows what is lie or not in the red apples world...
Cool effect you added there. It looks like a church window, and I like the warm color scheme too. Good job!
@sallyanne
Thanks. :)
Good points. The foot and leg are seen pointing towards us which means they are seen in perspective but you are right that the foot still appeared too large. I shrunk it down a bit now, while further enhancing the depth cues a bit - made for an interesting experiment too.
Her breast was actually correct, but the shadow cast by her hand made the left breast less visibly pronounced. I added some more visual cues to guide the eye, hopefully better now. Thanks for the comments!
Thanks, the ceiling shadows are subtle but very intentionally placed here. One can make an argument both for and against her left leg (-stump) being lit or not since there is, indeed, another source of light there. After some deliberation I went with your suggestion though, shading the stump more helps to ground here on the stool a little better I think. Thanks for the feedback! :D
Griatch
PostPosted: Wed Mar 16, 2016 2:24 pm  (#11)
Griatch wrote:
@Wallace
Griatch
I'm surprised you didn't catch this before posting.
Nonetheless,
I've always struggled to render hands and feet in any medium.
My hats off to you Griatch
 Post subject: Re: Red Apples Lie - Barfly (updated)
PostPosted: Wed Mar 16, 2016 2:31 pm  (#12)
I like this moody image very much Griatch; she is a moody shadow in a shadowy world.
PostPosted: Wed Mar 16, 2016 2:40 pm  (#13)
I can see why that may seem surprising, but it's partly an artefact of my work process. When working with an image, it's easy to go "blind" to it - one knows so well what one intends to convey, and that knowledge may occlude what is actually being conveyed. This is a very real and common problem for any painter. This is one of the reasons one "mirrors" the image repeatedly to "freshen" one's eyes. It's also the reason many artists let the image "sit" for a while before publishing - so they can come back to it with "fresh" eyes and spot errors.
Personally, I prefer not to wait - I prefer to call the image "preliminarily done" and put it online right away. I find that this speeds up the corrective process - it helps include the fresh eyes of others next to my own. Other people give different perspectives, tends to clarify what is unclear and gives feedback that often allows me to correct errors and misconceptions all in one fell swoop. Thanks for contributing to this process. :)
@oldmangrumpy
Thanks, Red Applies Lie is probably my most gloomy story/world/concept. :)
Griatch
PostPosted: Wed Mar 16, 2016 2:49 pm  (#14)
you're perfectly right, Griatch, it's more risky (prone to errors) to draw from own fantasy that from life (and even from life sometimes a painter paints what he thinks he is seeing, instead of what he really sees....)
PostPosted: Wed Mar 16, 2016 5:05 pm  (#15)
Btw shouldn't we start a "GimpChat for a second crutch" fund raiser? Having only one crutch is likely making her life very difficult (she used to have two, but in recent drawings she's got only one left).
PostPosted: Wed Mar 16, 2016 5:11 pm  (#16)
I'm loving the depth cues - blurring the background has really brought the focus onto her face and the red bottle and the extra shadows on her thigh work really well in my opinion. Nice work Griatch :).
PostPosted: Wed Mar 16, 2016 5:16 pm  (#17)
@ofnuts
Hehe, that sounds like a fun fundraiser! I guess she put the other crutch down on the floor since it looked too messy to have her hold up both. ;)
(Btw, this image has another big "artistic license" that I've not seen anyone comment or reflect about yet. Due to how the flow worked out, the image is mirrored. This simply looked better, but it means that for once it's her left leg that is missing, not the right one as usual ... ;) )
@Artloader
Great, good to hear the depth cues is not messing up too badly. Felt it worth to experiment with.
Griatch
PostPosted: Mon Mar 21, 2016 2:55 pm  (#18)
Did some further minor polishing. Should be done with this now.
Griatch
PostPosted: Mon Mar 21, 2016 3:29 pm  (#19)
Griatch
PostPosted: Tue Mar 22, 2016 2:03 am  (#20)
Griatch I like your whole work as they show so much detail and expression. You have great artistic talent. :clap
