It is currently Fri Nov 20, 2026 12:56 am
 Post subject: Rosary
PostPosted: Thu Mar 17, 2016 4:47 am  (#1)
Hi,
I bought a prayer bead sometime ago. I wanted to draw it in some computer software. Previously I tried it in Inkscape but the result was not satisfactory. This time I tried to recreate it in Gimp and the result is not bad.
I am a new learner of Gimp and have recently learnt the use of bump mapping. I tried to utilize the bump mapping method for its creation. Bump maps are shown in the image.
Marble Texture used the bump map.
I created a brush from a single bead and then utilized it to stroke the path.
The Muslims, the Christians and the Jews have been using Dates and Prayer Beads since the ancient time. I may say that Prayer Beads and dates are linked. Font is 'Palm' font and this represents Dates in this image.
Thanks.
File comment: A Prayer Bead
 Post subject: Re: Rosary
PostPosted: Thu Mar 17, 2016 4:50 am  (#2)
I think it looks excellent.
PostPosted: Thu Mar 17, 2016 5:10 pm  (#3)
That's very nice, Rashid.
PostPosted: Sun Mar 20, 2016 4:43 pm  (#4)
The beads are very realistic looking.
PostPosted: Sun Mar 20, 2016 5:45 pm  (#5)
Found the font. Thanks Rashid.You're right, 2-ton, the beads are very realistic.
