It is currently Fri Nov 20, 2026 2:30 am
Post new topic Reply to topic  [ 142 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 Post subject: Another try at Circlism.
PostPosted: Tue Mar 22, 2011 5:50 pm  (#1)
I just had a brain phart, and this is a result from said phart. Did use the Stipple program (not GIMP) for the dots (same one that I used for the TSP art recently). I first fed the image into G'MIC's Contours>Gradient Norm to get the white outlines on Black background before feeding that resulting template into the Stipple program (that was the Phart). Used Saul's cool Mean Fill Script-fu for the dot colorization. Still, the result won't be as posh as this guys results, but I have little patience to paint individual Dots, so, for a lazy man like me, it's acceptable; hopefully you all will find it so too. :)
ref: http://www.morguefile.com/archive/display/47472
 Post subject: Re: Another try at Circlism.
PostPosted: Tue Mar 22, 2011 5:51 pm  (#2)
Very cool looking, can I ask what it is supposed to be? Or just abstract?
Either way, it looks really cool man :D
Don't worry I think very few people here have the patience to make that many little dots.
Willy
I'm back I think
PostPosted: Tue Mar 22, 2011 5:57 pm  (#3)
You DID NOT click the link, don't you ?
PostPosted: Tue Mar 22, 2011 6:02 pm  (#4)
Sorry I read the post and thought that was someone elses version of that where they drew all the little dots, by hand, which I really wouldn't comment about here... Sorry about that.
I'm back I think
PostPosted: Tue Mar 22, 2011 6:09 pm  (#5)
I was joking my was not a criticism...just i too often overlook the links and i tought the same could be happened to you ...and i pointed to the link because that guy does really amazing works
Also Lylejk often...but is very hard emulate Ben Heine circlistic artwork
PostPosted: Tue Mar 22, 2011 6:11 pm  (#6)
Holy cow lols Such a hipocrite, but just looked at his work and he is really good, Lyle yours look pretty close though, keep working and you can be just as good :D
I'm back I think
PostPosted: Tue Mar 22, 2011 6:15 pm  (#7)
PC's right; glad you humoured my results with your comments Willy, but "close" is the wrong word I'm afraid. Still, I'm a tad closer then before. ;)
PostPosted: Tue Mar 22, 2011 6:15 pm  (#8)
I never saw, before, can I?
I'm back I think
PostPosted: Tue Mar 22, 2011 8:42 pm  (#9)
This is different, done with Pixelitor, but I liked the outcome. Again it is different, but you can change it from spheres to dots.
Maybe I'm just odd? This is one of mine, made up of a couple thousand dots, that I made with a sharpie.
StippledPeanut by PhotoMasterGreg, on Flickr
My Sigs = My Photos
PostPosted: Tue Mar 22, 2011 9:38 pm  (#10)
Lyle, I was getting some really weird results with distance transform in G'MIC. Have you even tossed a PBM file into G'MIC to see what happens? Give it a shot, lol.
For whatever reason, the results in preview won't save to the image! GAH!
PostPosted: Tue Mar 22, 2011 9:41 pm  (#11)
PBM file ?
PostPosted: Tue Mar 22, 2011 9:47 pm  (#12)
Stippling file made using dithering in GIMP, basically indexing the image at 1 color, and then reducing the number of dots by lightening the image (lowering opacity of the original image, is one method).
PostPosted: Tue Mar 22, 2011 10:11 pm  (#13)
Big fan of stippling too Mahvin. Weighted Voronoi Stippling is just one form of it. Dithering using Floyd-Steinberg is another. I remember when I first started working in the offset printing business (didn't last long, but it flamed the passion that got me to where I am now) and doing research on all the dithering techniques. Ran across this cool article (same PDF article anyway; had to re-find it; lol) too. :)
PostPosted: Tue Mar 22, 2011 10:21 pm  (#14)
We're not on the same wavelength, Lyle. I was explaining PBM to PC. I used the pbm in Concorde, etc. I used the same pbm file in G'MIC and got weird previews that won't translate to the image.
PostPosted: Tue Mar 22, 2011 10:55 pm  (#15)
Ah; you know already that pbm is a bi-color (2 color indexed) format and I bet G'MIC don't like working in color spaces other then greyscale or higher bits. :)
PostPosted: Tue Mar 22, 2011 11:01 pm  (#16)
Johnny Depp never looked so good! :)
http://www.flickr.com/photos/benheine/4 ... 553428960/
Fascinating technique that he has.
PostPosted: Tue Mar 22, 2011 11:32 pm  (#17)
This one's one of my favorites. Man, it just seems you could automate this, but alas I guess you can't do it. lol
PostPosted: Tue Mar 22, 2011 11:41 pm  (#18)
i bet the opposite
But even if i win you are too far to offer me a beer :gaah !!
(luckily the same if the winner is you :mrgreen: )
PostPosted: Wed Mar 23, 2011 12:54 am  (#19)
Hey Lyle i thought i had a script to do something like this and among my very many i think i found it.I have looked and looked and can not find these python files anywhere on the net now.Nor could i find them at the registry for some reason.But they do alot according to what you are looking for.
Examples
Before using the magic mesh filter (a small dialog screenshot) - Python-FU/Create Layers/MagicMesh
Using the robot as an example:
Now with the robot image removed for clarity
I attached the pythons in a zip if any one is interested
Their are 3 files - MagicMesh3 SVG - MagicMesh2 mask - and reg MagicMesh
MagicMesh-v.1.0.zip [5.36 KiB]
Downloaded 160 times
PostPosted: Wed Mar 23, 2011 1:03 am  (#20)
Then if you duplicate the dotlayer a bunch of times you can then add the original image on top set to hardlight-
You will find them in the menu here-
You can get some very interesting results playing with the sizes too. :)
