It is currently Fri Nov 20, 2026 12:28 am
Post new topic Reply to topic  [ 317 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
 Post subject: Ive got Wood!
PostPosted: Mon Apr 18, 2016 7:54 pm  (#1)
Everything seems to be mettle and plastic these days, So I thought wood backgrounds/Wallpapers would be something to try, after getting the idea from someone on the Deco thread.
So here yah go
 Post subject: Re: Ive got Wood!
PostPosted: Mon Apr 18, 2016 7:57 pm  (#2)
I have found that the beautify plug in works best because, it keeps a lot of the wood detail.
Where,BRL looses and distorts the grain and gives it a plastic look
PostPosted: Mon Apr 18, 2016 8:01 pm  (#3)
PostPosted: Mon Apr 18, 2016 9:05 pm  (#4)
Nice work Norseman143 and great use of the Beautify plugin. :bigthup
PostPosted: Mon Apr 18, 2016 9:21 pm  (#5)
Thanks Wallace
I was kind of bored,so I started this thread
PostPosted: Mon Apr 18, 2016 9:46 pm  (#6)
Nicely done.
Just want to ask you one question though. You are a Norseman but not a Nordic (space alien being that is) right? lolol
PostPosted: Tue Apr 19, 2016 1:27 am  (#7)
Nice. :) So exactly how do you do that with the beautify plugin? Want to show us in a tut?
PostPosted: Tue Apr 19, 2016 8:10 am  (#8)
I would like to see that also. It looks like fun. :yes
PostPosted: Tue Apr 19, 2016 10:29 pm  (#9)
I will do the best I can to explain How I do it. There may be easier ways to get the same results using tools within Gimp, but I do things simplistically, That, and I dont know how to do some of the fancy stuff others do.
First,go to a site with wood patterns, preferably with different colors and wood grains, copy them to your patterns.
Find an image you want. Break it down to how many colors that are in the image'
In this case, I will use the Minnesota Viking Norseman logo.which has 5 colors, Gold,White,Tan,Black and Purple
So, instead of Layers, I open the design 5 times instead of just layering them all in one. Because one filter I use
for a different effect squishes everything down, so I got used to opening it separately.
Black
Gold
Purple
Tan
White
You have to make sure everything in the background is transparent and make sure the shadow is shut off in the beautify plugin
I set the fuzzy select and color select to about 30. But depending on the image, you will get slag, or unwanted
pixels left so you have to alpha to selection, and then erase the unwanted stuff and just keeping the color that you are working on
I suggest, if you plan on using the image again, save all the layers as PNG so you dont have to do it all over again
Alpha to selection, pick the wood grain you want to replace the color with.Beautify Plugin the WOOD in your patterns menu Remember to shut the shadow off
When you have all the sections with the wood grain you want, copy and paste them to one image,save it, then decide what you want for the background and done
So if you saved all the parts, this method works good with the Plastic and glass plugin as well
I hope this made some sort of sense to you guys
PostPosted: Tue Apr 19, 2016 10:33 pm  (#10)
Here is the same method using the plastic and glass plugin
PostPosted: Wed Apr 20, 2016 2:01 am  (#11)
I assume you use the "Shine alpha" under the beautify plugin?
It was the only one I could make sense of....I couldn't see anything else there that gave stuff a shiny look.
Here is my first try.
PostPosted: Wed Apr 20, 2016 3:34 am  (#12)
Sallyanne - thanks for the heads up; I was trying to work out what to use in Beautify but this is really good old Graechan's 'Image Shine' script in action ...
... but it is good to be reminded of it :)
PostPosted: Wed Apr 20, 2016 5:33 am  (#13)
Nice OMG :)
PostPosted: Wed Apr 20, 2016 7:55 am  (#14)
I have been looking at my Beautify and don't see a "Shine alpha". Are there more than one Beautify plugins I wonder ?
Mine creates different borders on one setting, another says basic, lomo, studio,fashion,art.gradient, another setting is skin whitening.
Is this the same Beautify plugin ?
Never mind, I found the shine plugin with the search. :oops:
PostPosted: Wed Apr 20, 2016 8:23 am  (#15)
I used to have that plug in with the logo, skin whitening, etc. but now it's gone. Where can I get it?
PostPosted: Wed Apr 20, 2016 8:47 am  (#16)
registry.gimp.org says to download it here github.com
I forgot to add beautify shine here gimpscripts
PostPosted: Wed Apr 20, 2016 9:52 am  (#17)
My first try, it had to many color shades but I love this plugin.
PostPosted: Wed Apr 20, 2016 12:10 pm  (#18)
Thanks for showing me how to do this Norseman143.
I used the index to reduce the number of colors for me to 4 on this one.
PostPosted: Wed Apr 20, 2016 6:19 pm  (#19)
They are really nice Tom - are you a sparky? ;)
PostPosted: Wed Apr 20, 2016 8:09 pm  (#20)
Serious Tom, that is too complicated. I have no idea what it's telling me to do.
