Uff anytime i think to have finished i stumbled on something interesting
Very last is the effect of a double invertion
Effect is
without, would be
the ORIGINAL was
The double invertion trick is very simple:
1) invert the source image
2) apply the Stained Glass filter (there i used my version with the Merging mode set to grain merge, anyway will effect also the standard version)
3) Invert the result
I found out playing with siluettes , in particular with one with very light BG, i noticed how much different was the effect on solid black respect on solid white ,
so i tried also with images with more normal colors...
and you see the result
Uff, another option to add...I will never finish?
i started only because was looking so simple....
