It is currently Thu Nov 19, 2026 9:37 pm
 Post subject: Playing with chisel or carve
PostPosted: Wed Jul 13, 2016 9:51 am  (#1)
I got a pleasing effect by selecting some color on the rocks - filling with OMG frosted glasstile pattern and running chisel and carve
 Post subject: Re: Playing with chisel or carve
PostPosted: Wed Jul 13, 2016 1:51 pm  (#2)
I like it RJKD, it's interesting that effect. :bigthup
PostPosted: Tue Sep 20, 2016 5:24 pm  (#3)
I really like the effect on the rocks. They look pretty, and also very cold!
PostPosted: Tue Sep 20, 2016 6:59 pm  (#4)
RJKD - nice one :clap
I will have to play with that effect.
PostPosted: Mon Oct 24, 2016 1:42 am  (#5)
To those GC members (and others) who may have had a look at some recent tutorials I posted on the 'Chisel or Carve' filter, I think I owe you an apology. :oops:
In those tutorials I expressed my admiration for the dynamics of this filter and what it can produce. However, some further play with it recently has shown me that there are yet more elements that I have now discovered and which I did not address in those tutorials, particularly the last one where I used the filter against gradient patterns.
So please let me just point out some additional manipulations you may like to try out :
1. Try using 'colors>colorize' against the chisel/carve layer to add a softer hue to the feature – the gold gradient image below features this modification.
2. The default 'blend mode' for the filter is 'hard light' at 80% opacity. Try using different combinations, e.g. change the blend mode to 'overlay', then duplicate the layer and change its blend mode to 'multiply'. The red centred and green gradient image below features this approach. I also used 'burn mode' for one of the 'chisel/carve' layers in the gold gradient image too.
3. I probably referenced this next method but did not emphasise it sufficiently. The red/green gradient image referenced in 2 above also features several layers where the selection has been chiselled on the outside and carved on the inside. I really like that feature and again different blend modes were used.
4. Also try reversing the approach in 3 above. The third image below has a carved outside and chiselled inside, once more with modified blend modes.
Oh well ... never stop learning!
PostPosted: Mon Oct 24, 2016 2:18 am  (#6)
Fantastic work OMG!
:jumpclap
PostPosted: Mon Oct 24, 2016 7:33 am  (#7)
Beautiful creations OMG thank you. :clap
PostPosted: Mon Oct 24, 2016 5:15 pm  (#8)
I like playing with Chisel/Carve.
PostPosted: Fri Oct 28, 2016 8:06 pm  (#9)
Still learning about this 'chisel or carve' filter and what it can produce (think my tuts were a little premature!!) - so given that mandalas are coming back, here is one made completely from 'chisel or carve' using selections from paths (Mareroq's new filter for shapes), with various different blend modes including dissolve and the colorize filter. I keep saying it :gimp
PostPosted: Fri Oct 28, 2016 9:02 pm  (#10)
Wow! I really like that one.
