It is currently Thu Nov 19, 2026 9:37 pm
 Post subject: String Theory.
PostPosted: Wed Aug 17, 2016 8:17 am  (#1)
ref: http://www.freeimages.com/photo/fuuy-man-1430826
Just felt like going nutty and it helps to start off with a picture of a nut. lol
https://www.flickr.com/photos/34520999@ ... 2/sizes/o/
 Post subject: Re: String Theory.
PostPosted: Wed Aug 17, 2016 9:16 am  (#2)
:kpix
who's the nut ;) ?
Looks similar to one of your other binges
PostPosted: Wed Aug 17, 2016 9:44 am  (#3)
He is, Sallyanne. I like using same images for different renders so folks know I'm not taking someone else's madness and passing it as my own. lol
PostPosted: Wed Aug 17, 2016 11:47 am  (#4)
Gives a whole new meaning to string theory! You know I want to ask how you do that!
PostPosted: Wed Aug 17, 2016 1:06 pm  (#5)
Different blendings of Stencil followed by Gradient Norm, Pat. Then, on top layer, ran Isophots (outline on transparent option). Applied a convolution step to make the facial imprint stronger and did a few other things as well, but the afore steps would get you close enough. As for a tut; forget it (and I'll PM you as to why). :)
PostPosted: Sat Aug 20, 2016 9:34 pm  (#6)
I worked a lot on this Lyle, but I can't get the string to look like yours. Anyway, here goes:
PostPosted: Sun Aug 21, 2016 12:54 pm  (#7)
Nothing ever looks like Lyles. :) Good try at it though.
PostPosted: Sun Aug 21, 2016 1:12 pm  (#8)
Don't forget the color to alpha step (black to alpha) and then do the blending. I did forget to add that I texturized the lines a bit too. ;)
PostPosted: Mon Aug 22, 2016 1:54 pm  (#9)
OK. I'll try again. How do you texturize lines?
