It is currently Thu Nov 19, 2026 10:15 pm
 Post subject: Psycho Delik
PostPosted: Wed Sep 07, 2016 4:51 pm  (#1)
I was experimenting with curves today and happened upon a fun effect I thought I'd share.
Here's the royalty-free parrot before;
And here's the parrot after a 5px Gaussian Blur to help the colors blend and then the new curve applied;
If you'd like to play with the curve, just copy the code in the spoiler below, paste it into a .txt file, then import the file into GIMP via the Curves dialog.
# GIMP curves tool settings
(GimpCurvesConfig "Psycho Delik"
(time 0)
(channel value)
(curve
    (curve-type smooth)
    (n-points 17)
    (points 34 0.000000 0.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 -1.000000 1.000000 1.000000)
    (n-samples 256)
    (samples 256 0.000000 0.003922 0.007843 0.011765 0.015686 0.019608 0.023529 0.027451 0.031373 0.035294 0.039216 0.043137 0.047059 0.050980 0.054902 0.058824 0.062745 0.066667 0.070588 0.074510 0.078431 0.082353 0.086275 0.090196 0.094118 0.098039 0.101961 0.105882 0.109804 0.113725 0.117647 0.121569 0.125490 0.129412 0.133333 0.137255 0.141176 0.145098 0.149020 0.152941 0.156863 0.160784 0.164706 0.168627 0.172549 0.176471 0.180392 0.184314 0.188235 0.192157 0.196078 0.200000 0.203922 0.207843 0.211765 0.215686 0.219608 0.223529 0.227451 0.231373 0.235294 0.239216 0.243137 0.247059 0.250980 0.254902 0.258824 0.262745 0.266667 0.270588 0.274510 0.278431 0.282353 0.286275 0.290196 0.294118 0.298039 0.301961 0.305882 0.309804 0.313725 0.317647 0.321569 0.325490 0.329412 0.333333 0.337255 0.341176 0.345098 0.349020 0.352941 0.356863 0.360784 0.364706 0.368627 0.372549 0.376471 0.380392 0.384314 0.388235 0.392157 0.396078 0.400000 0.403922 0.407843 0.411765 0.415686 0.419608 0.423529 0.427451 0.431373 0.435294 0.439216 0.443137 0.447059 0.450980 0.454902 0.458824 0.462745 0.466667 0.470588 0.474510 0.478431 0.482353 0.486275 0.490196 0.494118 0.498039 0.501961 0.505882 0.509804 0.513725 0.517647 0.521569 0.525490 0.529412 0.533333 0.537255 0.541176 0.545098 0.549020 0.552941 0.556863 0.560784 0.564706 0.568627 0.572549 0.576471 0.580392 0.584314 0.588235 0.592157 0.596078 0.600000 0.603922 0.607843 0.611765 0.615686 0.619608 0.623529 0.627451 0.631373 0.635294 0.639216 0.643137 0.647059 0.650980 0.654902 0.658824 0.662745 0.666667 0.670588 0.674510 0.678431 0.682353 0.686275 0.690196 0.694118 0.698039 0.701961 0.705882 0.709804 0.713725 0.717647 0.721569 0.725490 0.729412 0.733333 0.737255 0.741176 0.745098 0.749020 0.752941 0.756863 0.760784 0.764706 0.768627 0.772549 0.776471 0.780392 0.784314 0.788235 0.792157 0.796078 0.800000 0.803922 0.807843 0.811765 0.815686 0.819608 0.823529 0.827451 0.831373 0.835294 0.839216 0.843137 0.847059 0.850980 0.854902 0.858824 0.862745 0.866667 0.870588 0.874510 0.878431 0.882353 0.886275 0.890196 0.894118 0.898039 0.901961 0.905882 0.909804 0.913725 0.917647 0.921569 0.925490 0.929412 0.933333 0.937255 0.941176 0.945098 0.949020 0.952941 0.956863 0.960784 0.964706 0.968627 0.972549 0.976471 0.980392 0.984314 0.988235 0.992157 0.996078 1.000000))
(channel red)
(curve
    (curve-type smooth)
    (n-points 17)
    (points 34 0.000000 0.000000 -1.000000 -1.000000 0.124247 1.000000 -1.000000 -1.000000 0.248494 0.247485 -1.000000 -1.000000 0.372741 1.000000 0.498494 0.503018 -1.000000 -1.000000 -1.000000 -1.000000 0.625753 1.000000 -1.000000 -1.000000 0.750753 0.754527 -1.000000 -1.000000 0.876506 1.000000 -1.000000 -1.000000 1.000000 1.000000)
    (n-samples 256)
    (samples 256 0.000000 0.045377 0.090672 0.135802 0.180683 0.225234 0.269372 0.313013 0.356076 0.398478 0.440136 0.480967 0.520890 0.559820 0.597676 0.634374 0.669833 0.703969 0.736700 0.767943 0.797616 0.825636 0.851920 0.876385 0.898949 0.919530 0.938044 0.954409 0.968543 0.980362 0.989784 0.996726 1.000000 1.000000 0.998239 0.990640 0.978972 0.963542 0.944657 0.922625 0.897753 0.870348 0.840718 0.809169 0.776010 0.741546 0.706086 0.669938 0.633407 0.596802 0.560429 0.524597 0.489611 0.455781 0.423412 0.392812 0.364289 0.338149 0.314700 0.294249 0.277104 0.263572 0.253960 0.247485 0.249564 0.255628 0.265417 0.278671 0.295130 0.314534 0.336623 0.361138 0.387817 0.416402 0.446631 0.478246 0.510986 0.544591 0.578802 0.613358 0.647999 0.682465 0.716497 0.749834 0.782217 0.813385 0.843078 0.871037 0.897002 0.920712 0.941907 0.960328 0.975715 0.987807 0.996345 1.000000 1.000000 1.000000 0.997645 0.991013 0.981799 0.970206 0.956439 0.940701 0.923198 0.904133 0.883711 0.862136 0.839612 0.816343 0.792534 0.768389 0.744112 0.719907 0.695979 0.672532 0.649770 0.627898 0.607119 0.587638 0.569659 0.553387 0.539025 0.526778 0.516851 0.509446 0.504770 0.503018 0.504288 0.507996 0.513991 0.522119 0.532229 0.544169 0.557786 0.572928 0.589442 0.607177 0.625980 0.645700 0.666183 0.687277 0.708831 0.730692 0.752708 0.774726 0.796595 0.818161 0.839274 0.859780 0.879528 0.898365 0.916138 0.932697 0.947888 0.961559 0.973558 0.983732 0.991930 0.998000 1.000000 1.000000 1.000000 1.000000 1.000000 0.997672 0.992640 0.986352 0.978922 0.970465 0.961093 0.950922 0.940064 0.928635 0.916749 0.904519 0.892059 0.879483 0.866907 0.854442 0.842205 0.830308 0.818865 0.807992 0.797801 0.788407 0.779924 0.772466 0.766147 0.761080 0.757381 0.754527 0.755112 0.756821 0.759588 0.763346 0.768028 0.773568 0.779899 0.786953 0.794664 0.802966 0.811791 0.821073 0.830744 0.840739 0.850990 0.861430 0.871993 0.882612 0.893220 0.903751 0.914136 0.924311 0.934207 0.943759 0.952899 0.961560 0.969676 0.977180 0.984005 0.990084 0.995351 0.999739 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000))
(channel green)
(curve
    (curve-type smooth)
    (n-points 17)
    (points 34 0.000000 0.000000 -1.000000 -1.000000 0.125000 1.000000 -1.000000 -1.000000 0.249247 0.247485 -1.000000 -1.000000 0.371235 1.000000 -1.000000 -1.000000 0.497741 0.501006 -1.000000 -1.000000 0.625000 1.000000 -1.000000 -1.000000 0.753765 0.754527 -1.000000 -1.000000 0.873494 1.000000 -1.000000 -1.000000 1.000000 1.000000)
    (n-samples 256)
(channel blue)
(curve
    (curve-type smooth)
    (n-points 17)
    (points 34 0.000000 0.000000 -1.000000 -1.000000 0.123494 1.000000 -1.000000 -1.000000 0.250000 0.253521 -1.000000 -1.000000 0.371988 1.000000 -1.000000 -1.000000 0.497741 0.503018 -1.000000 -1.000000 0.625753 1.000000 -1.000000 -1.000000 0.750753 0.754527 -1.000000 -1.000000 0.875000 1.000000 -1.000000 -1.000000 1.000000 1.000000)
    (n-samples 256)
(channel alpha)
(curve
    (curve-type smooth)
    (n-points 17)
    (n-samples 256)
    (samples 256 0.000000 0.003922 0.007843 0.011765 0.015686 0.019608 0.023529 0.027451 0.031373 0.035294 0.039216 0.043137 0.047059 0.050980 0.054902 0.058824 0.062745 0.066667 0.070588 0.074510 0.078431 0.082353 0.086275 0.090196 0.094118 0.098039 0.101961 0.105882 0.109804 0.113725 0.117647 0.121569 0.125490 0.129412 0.133333 0.137255 0.141176 0.145098 0.149020 0.152941 0.156863 0.160784 0.164706 0.168627 0.172549 0.176471 0.180392 0.184314 0.188235 0.192157 0.196078 0.200000 0.203922 0.207843 0.211765 0.215686 0.219608 0.223529 0.227451 0.231373 0.235294 0.239216 0.243137 0.247059 0.250980 0.254902 0.258824 0.262745 0.266667 0.270588 0.274510 0.278431 0.282353 0.286275 0.290196 0.294118 0.298039 0.301961 0.305882 0.309804 0.313725 0.317647 0.321569 0.325490 0.329412 0.333333 0.337255 0.341176 0.345098 0.349020 0.352941 0.356863 0.360784 0.364706 0.368627 0.372549 0.376471 0.380392 0.384314 0.388235 0.392157 0.396078 0.400000 0.403922 0.407843 0.411765 0.415686 0.419608 0.423529 0.427451 0.431373 0.435294 0.439216 0.443137 0.447059 0.450980 0.454902 0.458824 0.462745 0.466667 0.470588 0.474510 0.478431 0.482353 0.486275 0.490196 0.494118 0.498039 0.501961 0.505882 0.509804 0.513725 0.517647 0.521569 0.525490 0.529412 0.533333 0.537255 0.541176 0.545098 0.549020 0.552941 0.556863 0.560784 0.564706 0.568627 0.572549 0.576471 0.580392 0.584314 0.588235 0.592157 0.596078 0.600000 0.603922 0.607843 0.611765 0.615686 0.619608 0.623529 0.627451 0.631373 0.635294 0.639216 0.643137 0.647059 0.650980 0.654902 0.658824 0.662745 0.666667 0.670588 0.674510 0.678431 0.682353 0.686275 0.690196 0.694118 0.698039 0.701961 0.705882 0.709804 0.713725 0.717647 0.721569 0.725490 0.729412 0.733333 0.737255 0.741176 0.745098 0.749020 0.752941 0.756863 0.760784 0.764706 0.768627 0.772549 0.776471 0.780392 0.784314 0.788235 0.792157 0.796078 0.800000 0.803922 0.807843 0.811765 0.815686 0.819608 0.823529 0.827451 0.831373 0.835294 0.839216 0.843137 0.847059 0.850980 0.854902 0.858824 0.862745 0.866667 0.870588 0.874510 0.878431 0.882353 0.886275 0.890196 0.894118 0.898039 0.901961 0.905882 0.909804 0.913725 0.917647 0.921569 0.925490 0.929412 0.933333 0.937255 0.941176 0.945098 0.949020 0.952941 0.956863 0.960784 0.964706 0.968627 0.972549 0.976471 0.980392 0.984314 0.988235 0.992157 0.996078 1.000000)))
# end of curves tool settings
One tip, this curve works best with colorful images. Black stays unchanged and any shade of gray, including white, acts as though you've only tweaked the value. I may experiment to see if I can get white to play along.
A second tip, fine details result in a grainy picture. I had to add a blur to the parrot to get the smooth regions of color.
Just a short while ago I was a complete idiot when it comes to GIMP. Today, after many hours of practice, reading, and watching tutorials, I am proud to say I am an incomplete idiot.
 Post subject: Re: Psycho Delik
PostPosted: Thu Sep 08, 2016 6:56 am  (#2)
Wow that is pretty psychedelic Sasquatch! It has an almost metallic feel to it. Nice work :).
PostPosted: Thu Sep 08, 2016 7:40 am  (#3)
Thanks. I've gained a new appreciation for the power of the Curves tool. I plan to experiment more.
PostPosted: Thu Sep 08, 2016 12:23 pm  (#4)
I obtained a similar effect recently using Color>Map>Gradient map with a multi-rainbow gradient generated by script.
from __future__ import print_function
import math
bands=32
def line(i,rgb1,rgb2):
    r1,g1,b1=rgb1
    r2,g2,b2=rgb2
    l=i/float(bands)
    m=(i+.5)/float(bands)
    r=(i+1)/float(bands)
    return '%2.6f %2.6f %2.6f %2.6f %2.6f %2.6f 1.000000 %2.6f %2.6f %2.6f 1.000000 0 0 0 0' % (l,m,r,r1,g1,b1,r2,g2,b2)
f=open('./%d-steps.ggr' % bands,'w')
print('GIMP Gradient',file=f)
print('Name: %d-Steps' % bands,file=f)
print(str(bands),file=f)
for i in range(bands):
    v=math.sqrt(i*256./(255.*bands))
    r=v if i%3==0 else 0
    g=v if i%3==1 else 0
    b=v if i%3==2 else 0
    print(line(i,(r,g,b),(r,g,b)),file=f)
f.close()
(Code provided as is for those who want to play with it, some python experience may be required).
PostPosted: Fri Sep 09, 2016 12:05 am  (#5)
my personal contributions:
PostPosted: Sat Sep 10, 2016 6:08 am  (#6)
Dinasset, that one in the top/center of your montage is a great effect. How did you do that?
