It is currently Thu Nov 19, 2026 10:14 pm
 Post subject: Mycelium Puppy
PostPosted: Wed Sep 14, 2016 8:36 am  (#1)
Not really art in the correct sense. Just a filter ran on an image at default. I just had to try this plug-in again. Pretty cool filter. :bigthup
Settings (834 x 898 image size. Time it took for the Myce to eat and poop - 7 minutes
You can find the info here.
viewtopic.php?f=9&t=9271
Plug-in here
https://github.com/bootchk/pluginMycelium
Make sure you get pixmap also.
https://github.com/bootchk/pixmap
 Post subject: Re: Mycelium Puppy
PostPosted: Wed Sep 14, 2016 8:39 am  (#2)
Keep in mind if you open any new or import an existing RGB image while you run this filter or after its finished you need to change the <Image>Mode to RGB again as this plug-in switches it to gray-scale.
PostPosted: Wed Sep 14, 2016 9:01 am  (#3)
PY ignorant here Rod. How do I download and install please? I copied the file into TextEdit, renamed with .py extension (that's what my ditzy mind told me to do) and, of course, I did something very, very wrong.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Wed Sep 14, 2016 9:37 am  (#4)
Installing
Copy to the normal Gimp plugin directory for your platform:
- the file plugin-mycelium.py (a GIMP plugin written in Python)
- the directory pluginMycelium (a Python package)
- the directory pixmap (a Python package)
So you should have two folders
1) Pixmap
2) pluginMycelium
and plugin-mycelium.py all in your Plug-ins folder. Restart GIMP and you will find it under Filters>Map>
Open any image and run the filter.
