It is currently Fri Nov 20, 2026 5:42 pm
 Post subject: The Montain :)
PostPosted: Sun Sep 25, 2016 2:33 pm  (#1)
This photo I made at Steirmark/Austria.
Steps
1. Colors -> Saturation enhance
2. GMIC/Details -> Freaky Details
3. GMIC/Details -> Dynamic Range increase
:paint :paint :paint
Original Photo
End Result
Before and After
 Post subject: Re: The Montain :)
PostPosted: Sun Sep 25, 2016 2:38 pm  (#2)
I think that's the after and before.
looks awesome though.
PostPosted: Sun Sep 25, 2016 2:38 pm  (#3)
nice one
PostPosted: Sun Sep 25, 2016 2:39 pm  (#4)
my B&W transformation
PostPosted: Sun Sep 25, 2016 4:10 pm  (#5)
Very nice, Muhammed. Really emphasized the mountains.
Dinasset: The B&W version is nice also. What did you do?
PostPosted: Sun Sep 25, 2016 10:21 pm  (#6)
these are my steps, Pat:
Use Levels tool
1-cut the extreme values by setting input range (e.g.) from 16 to 239
2-increase Red luminosity by setting mean value (e.g.) to 1.6
3-increase Green luminosity by setting mean value (e.g.) to 1.4
4-decrease Blue luminosity by setting mean value (e.g.) to 0.5
then
5-desaturate the image by luminosity
6-duplicate the layer and set mode=Burn opacity at 60-70%
7-flatten
Try it
