It is currently Fri Nov 20, 2026 5:42 pm
 Post subject: Polyscape
PostPosted: Sun Oct 02, 2016 12:31 pm  (#1)
this one is more like poly-pencil-scape.
source image: colorful pencils
 Post subject: Re: Polyscape
PostPosted: Sun Oct 02, 2016 2:10 pm  (#2)
Did you desaturate the image after selection, Tin? It's very nice the effect. :)
PostPosted: Sun Oct 02, 2016 2:18 pm  (#3)
Thanks,
Nope, I don't touch the original background image.
I add a layer fill it with black (or white as long as it's a color that has RGB of the same value), then add layer mask of white, set mode to color, then paint mask with black where i want to reveal color.
The 2 circles are just gradient added on another layer.
PostPosted: Sun Oct 02, 2016 2:27 pm  (#4)
Thank you Tin. Another effect for me to try. :)
