It is currently Thu Nov 19, 2026 10:44 am
 Post subject: Dreams of a blue sphere
PostPosted: Wed Apr 06, 2011 9:40 pm  (#1)
not my last work but i like to share
Dreams of a Blue Sphere-combinations by PhotoComix_Mandala, on Flickr
in case you like you may click to grab the full size version (a 2650 x2650 png)
i did a few :mrgreen: other experiments on the same subject that you may see here..again click on the image to get the large or the original size
http://www.flickriver.com/photos/photoc ... 983205086/
you may have to scroll a little bit :hehe to see the last of the series that obviously may be the most interesting ... :sglasses
 Post subject: Re: Dreams of a blue sphere
PostPosted: Wed Apr 06, 2011 10:12 pm  (#2)
I'm thinking I would love to use these as a background in a different form, lightened up a little bit.
PostPosted: Wed Apr 06, 2011 10:19 pm  (#3)
go for it !
PostPosted: Wed Apr 06, 2011 10:39 pm  (#4)
Oh, man, what a collection. I love them all and hope I don't start seeing things in those blue spheres.
Stunning and elegant, PhotoComix.
This one, http://www.flickr.com/photos/photocomix_mandala/5002050850/, I think, is my favorite of them all - at least for the moment..
PostPosted: Wed Apr 06, 2011 11:19 pm  (#5)
When I use mirror arrays, it distorts my images. So, I'm perplexed. Is this why G'MIC has the expand image toggle?
PostPosted: Thu Apr 07, 2011 12:59 am  (#6)
Glad you like...that is one of my favorite too...
Do you hope that ? Sure ?
if don't see things there you badly need a good doctor and , i fear he will force you to wear very, very thick glasses.
I almost always use not even the expand but the repeat option:
do not expand correspond to scale down the original at 200%, should not distort but for sure will damage the quality, on the contrary mirroring by appending flipped duplicates mantain exactly the same quality of the original
well happy to show Oregonian favorite
Dreams of a Blue Sphere -Droste by PhotoComix_Mandala, on Flickr
PostPosted: Thu Apr 07, 2011 8:25 am  (#7)
Did you make that solely in GIMP? Looks like it has some sort of 3D program to create that effect with the Cement looking stuff
I'm back I think
PostPosted: Thu Apr 07, 2011 9:09 am  (#8)
the original image (that is not mine but from http://www.flickr.com/photos/schmiegl/ ) is below ...and yes, was created with a 3D program( i believe Bryce )
Kelp by Schmiegel [gone Deviant], on Flickr
i shamellessly admit that one of my favorite trick for successfully manipulation is start from excellent originals,even better if available at huge size and hi res
As many from schmiegl
PostPosted: Thu Apr 07, 2011 9:14 am  (#9)
I do have to agree completely :D
Those always make really cool transformations.
I'm back I think
PostPosted: Thu Apr 07, 2011 9:32 am  (#10)
PC I think I may have found something Funky with your script.
I am using an Orange Background with the color "ff8800" and whenever I run your Stained Glass Filter on it, it always changed Colors on me. I have tried it with a Black Line on it and a White Line and it always Lightens or Darkens.
I'm back I think
PostPosted: Thu Apr 07, 2011 9:58 am  (#11)
you mean the Psychedelic Glasswork Tyler ?
1) could you try to set Opacity to 0 ?
2)And if still happen :
could you check if the same color shift would happen by using the Stained Glass filter? just try to run it on a duplicate of same original image and then confront
please let me know !
(better on the filter topic :lol )
PostPosted: Thu Apr 07, 2011 10:03 am  (#12)
I looked on the Normal Stained Glass and I do not get the Same problem. I also tried setting the Opacity to 0 on your script and it still gave me the same problem.
I am using 1 layer, in 2.7 GIMP, 1.4.8.3 G'MIC, with ff8800 for the Background and then just a Black Line randomly drawn in on the Same layer.
I'm back I think
PostPosted: Thu Apr 07, 2011 10:41 am  (#13)
could you upload the xcf?
better if renaming first the layer with the original "original" (or even O )
PostPosted: Thu Apr 07, 2011 10:50 am  (#14)
Enjoy this was with Default Settings By the Way
I tried a few other settings but they all gave this same odd background color change
ForPC.xcf [429.39 KiB]
Downloaded 100 times
I'm back I think
PostPosted: Thu Apr 07, 2011 2:56 pm  (#15)
the code you use is different, it has another (function) name
please replace with this
#@gimp Psychedelic Glasswork Tiler : gimp_psyglass, gimp_psyglass_preview
#@gimp : sep = separator()
#@gimp : note = note("Stained Glass controls")
#@gimp : White separators = bool(false)
#@gimp : Edges = float(20,0,100)
#@gimp : Shading = float(0.1,0,0.5)
#@gimp : Thin separators = bool(1)
#@gimp : Equalize = bool(1)
#@gimp : note = note("To skip Layer Fx set Opacity to 0")
#@gimp : Layer Fx = choice("Grain Merge","Hard Light","Soft Light","Overlay","Color Burn ","Multiply",)
#@gimp : Opacity = float(1,0,1)
#@gimp : note = note("Quick Corrections and Special Fx")
#@gimp : Apply Mask = bool(true)
#@gimp : note = note(" Contrast Mask preset")
#@gimp : Raise Local Contrast = bool(false)
#@gimp : note = note("Local Normalization preset")
#@gimp : note = note("Mirrors Controls")
#@gimp : Activate Mirrors = bool(true)
#@gimp : Iterations = int(1,1,10)
#@gimp : X-offset = float(0,0,100)
#@gimp : Y-offset = float(0,0,100)
#@gimp : Array mode = choice(2,"X-axis","Y-axis","XY-axes","2XY-axes")
#@gimp : Initialization = choice("Original","Mirror X","Mirror Y","Rotate 90 deg.","Rotate 180 deg.","Rotate 270 deg.")
#@gimp : Expand size = _bool(false)
#@gimp : sep = separator(), Preview type = choice("Full","Forward horizontal","Forward vertical","Backward horizontal","Backward vertical")
#@gimp : sep = separator(), note = note("<small>Author : <i>PhotoComix;</i>. Latest update : <i>2011/03/30</i>.</small>")
gimp_psyglass :
-repeat @# -l[$>] -split_opacity -l[0]
-if {$1==0}
-blur 0.1 -stained_glass $2,$3,$4 -n 0,255
-elif {$1==1}
-negative -blur 0.1 -stained_glass $2,$3,$4 -n 0,255 -negative
-endif
-if $5 -equalize 256 -endif
--blur 0.9
-if {$6==0} -gimp_compose_grainmerge $7
-elif {$6==1} -gimp_compose_hardlight $7
-elif {$6==2} -gimp_compose_softlight $7
-elif {$6==3} -gimp_compose_overlay $7
-elif {$6==4} -gimp_compose_colorburn $7
-elif {$6==5} -gimp_compose_multiply $7
-endif
-if {$8==1} -gimp_contrast_swm 2,0,1,0 -endif
-if {$9==1} -gimp_normalize_local 2,6,5,20,1,3,0 -endif
-if $10 # Apply mirror effect.
-if {$15==1} -mirror x
-elif {$15==2} -mirror y
-elif {$15==3} -rotate 90
-elif {$15==4} -rotate 180
-elif {$15==5} -rotate 270
-endif
-array_mirror $11,$14,$16
-shift -$12%,-$13%,0,0,2
-endif
-endl -a c -endl -done
gimp_psyglass_preview :
-gimp_split_preview " -gimp_psyglass ${1--2}",$-1
do you remember where you got that code so i may correct there ?
PostPosted: Thu Apr 07, 2011 2:57 pm  (#16)
It was in one of your other Posts, I remember you gave it to us after the Preview didn't work after turning off mirrors
This new one, Preview Function does not work for me. 2.7 GIMP
I'm back I think
PostPosted: Thu Apr 07, 2011 3:02 pm  (#17)
ok i will search and delete this is the real one,
you may see the difference here
default
white lines
PS maybe for the first you will get a more interesting result using color burn or multiply ,i just run with the default
PostPosted: Thu Apr 07, 2011 3:04 pm  (#18)
I still get a Preview Error :/ No matter what settings I have
With the New one Even
I'm back I think
PostPosted: Thu Apr 07, 2011 3:08 pm  (#19)
OOOPSS ...sorry a copy & paste error (last line went MIA )
Fixed now ! you may try again
PostPosted: Thu Apr 07, 2011 3:16 pm  (#20)
I have another problem now, I am running it and I keep getting a completely Black finished Product
I'm back I think
