It is currently Thu Nov 19, 2026 8:14 pm
 Post subject: Raised tiled mosaic.
PostPosted: Sat Nov 12, 2016 1:02 am  (#1)
Tran's cool gift to us can be used to create these as well. Just used the old GIMP distort>mosaic plugin to start things off this time. :)
ref: http://www.fontplay.com/freephotos/seve ... 406-03.jpg
 Post subject: Re: Raised tiled mosaic.
PostPosted: Sat Nov 12, 2016 11:02 am  (#2)
Nice Lyle! Did you use the multi shadows filter by Tran for that one?
PostPosted: Sat Nov 12, 2016 11:36 pm  (#3)
Sorry for my late reply Rod (new schedule). Yes; used Tran's multi-layer and multi-layer shadow python plugins. :)
PostPosted: Sat Nov 12, 2016 11:50 pm  (#4)
Good to see you get so many uses out it, Lylejk!
I did something else on this one.
stack layers by colors, then multiple shadows, then used the reggae flag to offset it for each layer, I wasn't sure what layer mode to use, so i used darken only on top of the flag and inverted cut to leave behind the flag's offset for each layer.
PostPosted: Sat Nov 12, 2016 11:55 pm  (#5)
That is pretty cool, Tran. :)
PostPosted: Sun Nov 13, 2016 1:34 am  (#6)
your mosaic is cool! looks like actual tiles
PostPosted: Sun Nov 13, 2016 1:36 am  (#7)
what's a good layer mode to use of a grey scale or color to apply over layer of something like flag?
I might write a simple script to offset it, and visible from each layer invert to not have to do the effect i just did manually.
PostPosted: Sun Nov 13, 2016 2:25 am  (#8)
i guess i could let user choose layermode, yeah i 'll do that.
PostPosted: Sun Nov 13, 2016 3:29 am  (#9)
Hey that mosaic rose looks awesome Lyle!
I like your reggae mosaic too Tran :).
