It is currently Thu Nov 19, 2026 8:15 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Crazy Hedcut
PostPosted: Sun Nov 13, 2016 9:37 am  (#1)
Here the Gimp Art thread.
From now on we should use this one for showing our plays.
Just to start
nee12_by_echohowdy-d5j7mq9, as a Crazy Hedcut Drawing (intensitry=4.0).jpg [ 491.42 KiB | Viewed 5877 times ]
 Post subject: Re: Crazy Hedcut
PostPosted: Sun Nov 13, 2016 9:39 am  (#2)
I like the intertwining result, Diego. :)
PostPosted: Sun Nov 13, 2016 9:43 am  (#3)
I agree with Lyle, the intertwining lines shaping the object is fantastic. :) :clap
PostPosted: Sun Nov 13, 2016 9:44 am  (#4)
Thanks, Lyle.
As I said, all has started from one of your tuts, hence thanks for your original idea.
PostPosted: Sun Nov 13, 2016 9:54 am  (#5)
I don't know which option I like the best. :)
escalator-283448_1280-CrazyHedcutDrawing-intensity4-grayscale-source top-duplicate&merge.jpg
escalator-283448_1280-CrazyHedcutDrawing-intensity4-grayscale-source top-duplicate&merge.jpg [ 536.42 KiB | Viewed 5865 times ]
escalator-283448_1280-CrazyHedcutDrawing-intensity4-source top-golden look-duplicate&merge.jpg
escalator-283448_1280-CrazyHedcutDrawing-intensity4-source top-golden look-duplicate&merge.jpg [ 999.75 KiB | Viewed 5865 times ]
escalator-283448_1280-CrazyHedcutDrawing-intensity4-source top-duplicate&merge.jpg
escalator-283448_1280-CrazyHedcutDrawing-intensity4-source top-duplicate&merge.jpg [ 856.91 KiB | Viewed 5865 times ]
PostPosted: Sun Nov 13, 2016 10:03 am  (#6)
On cityscapes
IMGP1091, as a Crazy Hedcut Drawing (intensitry=4.0) (Source on top).jpg [ 4.76 MiB | Viewed 5859 times ]
PostPosted: Sun Nov 13, 2016 10:04 am  (#7)
...and
IMGP1100, as a Crazy Hedcut Drawing (intensitry=7.0) (grayscale).jpg [ 3.09 MiB | Viewed 5859 times ]
PostPosted: Sun Nov 13, 2016 10:06 am  (#8)
...and
IMGP1104, as a Crazy Hedcut Drawing (intensitry=7.0) (Source on top).jpg [ 3.27 MiB | Viewed 5859 times ]
PostPosted: Sun Nov 13, 2016 10:07 am  (#9)
Play Time!!!
PostPosted: Sun Nov 13, 2016 10:08 am  (#10)
Superb, beautiful results. :) :kpix
flores-y-cristal-CrazyHedcutDrawing-moderate darken-intensity7-source.jpg [ 726.67 KiB | Viewed 5858 times ]
astronira-213674-CrazyHedcutDrawing-intensity6-source.jpg [ 2.79 MiB | Viewed 5858 times ]
abbey-1160492_1280-CrazyHedcutDrawing-brighten-intensity7-source.jpg [ 1.07 MiB | Viewed 5858 times ]
PostPosted: Sun Nov 13, 2016 10:10 am  (#11)
Thanks Pat, for best results I would suggest to use size (W+H) in the range 2100-3000
PostPosted: Sun Nov 13, 2016 10:23 am  (#12)
I continue playing...
music-1808224-CrazyHedcutDrawing-intensity4-grayscale.jpg [ 1.45 MiB | Viewed 1898 times ]
music-1808224-CrazyHedcutDrawing-intensity4-inverted colours.jpg [ 2.69 MiB | Viewed 1898 times ]
music-1808224-CrazyHedcutDrawing-intensity4-source.jpg [ 2.59 MiB | Viewed 1898 times ]
PostPosted: Sun Nov 13, 2016 10:30 am  (#13)
IMG_5167-2800x2100-crazy hedcut drawing-intensity4.JPG [ 5.17 MiB | Viewed 1898 times ]
PostPosted: Sun Nov 13, 2016 10:33 am  (#14)
Thanks, Issabella.
Flowers can be good candidates for "inverted colours"
Sunflower_sky_backdrop, as a Crazy Hedcut Drawing (intensitry=4.0) (Source on top) (inverted colours) (Dupl&Merge, SoftLight).jpg
Sunflower_sky_backdrop, as a Crazy Hedcut Drawing (intensitry=4.0) (Source on top) (inverted colours) (Dupl&Merge, SoftLight).jpg [ 2.27 MiB | Viewed 1897 times ]
PostPosted: Sun Nov 13, 2016 10:39 am  (#15)
The sunflower is beautiful. I'm applying it on all kind of pictures and I find all results are superb. :) :hi5
rosa_Meizeli_CrazyHedcut drawing-intensity6-golden.jpg [ 616.23 KiB | Viewed 1897 times ]
caballo-Fondo-CrazyHedcutDrawing-moderate darken-intensity7-source.jpg [ 1.31 MiB | Viewed 1897 times ]
basket_43780-CrazyHedcutDrawing-intensity6-source.jpg [ 1.82 MiB | Viewed 1897 times ]
PostPosted: Sun Nov 13, 2016 10:52 am  (#16)
and these.
BeforePerformance-as a crazy hedcut drawing-intensity7-duplicate&merge-source.jpg
BeforePerformance-as a crazy hedcut drawing-intensity7-duplicate&merge-source.jpg [ 715.67 KiB | Viewed 1896 times ]
BeforePerformance-as a crazy hedcut drawing-intensity7-grayscale.jpg [ 469.07 KiB | Viewed 1896 times ]
PostPosted: Sun Nov 13, 2016 11:12 am  (#17)
Playing with the layers in between gets some pretty cool effects as well.
PostPosted: Sun Nov 13, 2016 11:53 am  (#18)
A very nice result mahvin, :bigthup
Just I had to add one more in grayscale.
ballet-student-as a crazy hedcut drawing-intensity7-grayscale.jpg [ 2.18 MiB | Viewed 1894 times ]
PostPosted: Sun Nov 13, 2016 12:47 pm  (#19)
a few more. :)
motorbike-438464_1280-CrazyHedcutDrawing-intensity7-grayscale.jpg [ 555.31 KiB | Viewed 1891 times ]
ladies-1526072_1280-CrazyHedcutDrawing-intensity5-source.jpg [ 1.08 MiB | Viewed 1891 times ]
locomotive-60539_1280-CrazyHedcutDrawing-intensity7-source.jpg [ 938.16 KiB | Viewed 1891 times ]
PostPosted: Sun Nov 13, 2016 2:14 pm  (#20)
Playing (added a gradient as postprocessing)
