It is currently Fri Nov 20, 2026 8:28 pm
 Post subject: perfect green eye :)
PostPosted: Fri Apr 08, 2011 3:39 pm  (#1)
Original ImageImageafter does it look perfect?
[/align]
 Post subject: Re: perfect green eye :)
PostPosted: Fri Apr 08, 2011 3:41 pm  (#2)
Very Cool Looking Miguel :D
You should make a tutorial explaining this stuff :D
I'm back I think
PostPosted: Fri Apr 08, 2011 3:53 pm  (#3)
its easy dude jst zoom on the eye then select around the eye then go to colors color balance and mess around with the colors
PostPosted: Fri Apr 08, 2011 3:54 pm  (#4)
Brush in "hue" mode?
PostPosted: Fri Apr 08, 2011 3:58 pm  (#5)
well if u want to dude but i like to use the color balance on the color section
PostPosted: Fri Apr 08, 2011 7:26 pm  (#6)
There is much more power in the hue mode of paint tools. for instance, with a color gradient:
PostPosted: Fri Apr 08, 2011 8:40 pm  (#7)
The power of Gimp - Sounds like a good YouTube channel. :)
Cool eyeballs you alls hey that rhymed! - yes i did it on purpose shame on me.
PostPosted: Fri Apr 08, 2011 8:54 pm  (#8)
Very cool, Miguel. I love the reflection in the eye.
PostPosted: Fri Apr 08, 2011 9:49 pm  (#9)
Very cool looking. I agree with O. The reflection is awesome!
Come on people make some sigs for sig of the week!
PostPosted: Fri Apr 08, 2011 9:57 pm  (#10)
You may want to feather the edges out a little bit, because the green eye has a bit of the original blue, showing in the white along the edge of the green.
Otherwise this is perfect!
Below is my own eye from a couple of years ago. Very similar to what you're doing here.
Rainbow Eye by PhotoMasterGreg, on Flickr
My Sigs = My Photos
PostPosted: Sat Apr 09, 2011 1:40 pm  (#11)
how do i make the rainbow eyes?
