It is currently Thu Nov 19, 2026 7:06 pm
 Post subject: Night shore
PostPosted: Sat Dec 17, 2016 8:56 am  (#1)
 Post subject: Re: Night shore
PostPosted: Sat Dec 17, 2016 9:24 am  (#2)
I like your result and the far lights on the shore. Good job, RJKD :bigthup
PostPosted: Sat Dec 17, 2016 9:43 am  (#3)
RJKD,
sorry to disappoint you, but I don't understand your composition (in terms of: what each piece represents, how lights and shadows combine each others...); they look "inconsistent" to me.
Sorry.
But you have estimators...
PostPosted: Sat Dec 17, 2016 9:57 am  (#4)
I understand that RJKD has represented a night shore scene on the background and a pier on the foreground with a stone wall too. The bird is under Moon light. I see the whole composition like that. :)
PostPosted: Sat Dec 17, 2016 10:13 am  (#5)
I think shadows are tricky and I agree the overall composition is a bit inconsistent, however for a first attempt I'm quite pleased, enough to keep experimenting, thank you both for your feedback :hi5
Night_shore.zip [1.14 MiB]
Downloaded 208 times
PostPosted: Sat Dec 17, 2016 4:45 pm  (#6)
The main problem is that the pier extends to the opposite shore... (assuming this is what the two lines of light are).
Some more things that make the eyes itch a bit:
- the moon is much too big
- the moon has no reflection in water
- the seagull reflects light... from where? Actually it should appear as a shadow in the moon reflection
- the seagull exactly in the axis of the pier makes you wonder what it is (some fixture on the pier?)
- no good explanation for the shadow on the right part of the pier. IMHO the pier should somehow vanish in the shadow.
Pretty good start, just requires some adjustments :)
PostPosted: Sun Dec 18, 2016 6:02 am  (#7)
Thanks ofnuts, great feedback, much appreciated. :tyspin
PostPosted: Sun Dec 18, 2016 8:08 am  (#8)
I like this RKJD, I like the concept of walking out on a pier at night - especially if it leads to some floating lights in the water like that - what are those by the way?
I almost didn't see the shadow of the person to the right of the pier - I guess that would explain the right part of the pier being in shadow.
The shadow also tells us that there is a light source behind the camera pointing out towards the seagull so I can see why the seagull is lit.
I think Ofnuts is right about having more reflections in the water - particularly of the moon - that would work well.
Good effort though mate - keep it going :).
PostPosted: Sun Dec 18, 2016 11:13 am  (#9)
I am delighted with your feedback, this is a precious image I have in my head, as a youth I spent many a night sitting on the beach.
Contrasting and highlighting shadows I'm struggling with just now.
Night_shore.zip [1.24 MiB]
Downloaded 142 times
PostPosted: Sun Dec 18, 2016 6:19 pm  (#10)
Much better... So now the first two lines are waves breaking on the strand. The seagull is OK, the moon is about the right size. But:
- The third line of waves can't extend to the opposite shore.
- The lines of waves are more or less parallel to the shore. A pier is usually perpendicular to the shore. So waves and pier should be perpendicular.
- The distance of the waves also means this is low tide with a fairly wide beach. Beaches being usually made of fairly clear material, we should see something else than black.
- Unless the person has an air defense light right behind the head, there cannot be a shadow this sharp that extends for the length of the pier.
- The moon reflection is always exactly between the moon and the spectator. It can't be sideways as it is right now.
You are going somewhere. Keep it up.
PostPosted: Mon Dec 19, 2016 3:03 pm  (#11)
Really appreciate the critique - take 3
Night_shore.zip [3.1 MiB]
Downloaded 89 times
PostPosted: Mon Dec 19, 2016 6:16 pm  (#12)
RJKD - some nice work there; hope you do not mind but I had a quick play with your image -I like starry skys and a soft reflection -
PostPosted: Tue Dec 20, 2016 4:34 am  (#13)
The horizon beyond the opposite shore makes it appear a lot closer. No it looks like a nearby rock with fireflies.
PostPosted: Tue Dec 20, 2016 7:05 am  (#14)
OMG, I'm delighted you had a play, the 4 things I couldn't accomplish -
1) To have a good starry night sky which wasn't pure black
2) How to soften the moonlight nicely
3) How to achieve a feint highlight on the contour of the person
4) The overall composition, which thankfully ofnuts has guided me with
Would you mind posting you xcf so I can see how you achieved your outcome please?
I ran GIMPressionist dotify on the 'sand' for some texture
I will keep the composition of green sea and a gradient from horizon (sea top) to top of image.
I always find that images look so much better when viewed as desktop size (mine being 1920 x 1080)
:tyspin
PostPosted: Tue Dec 20, 2016 3:35 pm  (#15)
RJKD - your zipped xcf + a readme text document attached as requested.
Night_shore.zip [4.52 MiB]
Downloaded 146 times
