It is currently Thu Nov 19, 2026 7:11 pm
 Post subject: Plasmic Scarecrow.
PostPosted: Fri Dec 23, 2016 1:19 am  (#1)
OK; I know it's not Halloween, but this one using my new flow came out cool I thought. :)
 Post subject: Re: Plasmic Scarecrow.
PostPosted: Fri Dec 23, 2016 2:12 am  (#2)
Well done Lyle. I like that effect you did. :kpix :bigthup
PostPosted: Fri Dec 23, 2016 8:15 am  (#3)
Thanks Issabella. Now I wish I would have added some sparks. lol
PostPosted: Fri Dec 23, 2016 4:22 pm  (#4)
Lyle, You're on a roll!!
PostPosted: Fri Dec 23, 2016 6:35 pm  (#5)
Appreciate the words, Pat. I'm just so impressed how realistic Make Squiggly is at rendering plasma. I mean, you even get the magnetic flux ley lines effects that you see in such things. :)
PostPosted: Sat Dec 24, 2016 2:59 am  (#6)
Please, continue your experiments when you can. :) :bigthup
PostPosted: Mon Dec 26, 2016 10:22 am  (#7)
Here is a try, from the end of the script so far.
i am learning a lot from this one.
Can't find how to run Colors > map > gradient color as of yet.
it works fine up until this point (no bleed color to transparent though, don't know
how to call that one - replaced with 'make solid' in gmic.)
PostPosted: Mon Dec 26, 2016 11:21 pm  (#8)
Sorry for my belated reply, Brian (just got off work). Looks extremely promising. What I do is blend two passes (one more dense and spread and the other more singular) by adjusting the Segmentation smooth slider in Make Squiggley. I then also run Morphology to squeeze the tendrils (set to 2). :)
PostPosted: Tue Dec 27, 2016 10:13 am  (#9)
No need to be sorry!!!
I don't have internet at home so many times
am unable to communicate (other times the
thumb drive gets left behind)....
Thank you for the tips!
here are a couple examples
using solidify, didn't extract, didn't desaturate.
In the program, leaving option to solidify or not as it seems most important
to the flow and something requiring finesse.
Next on list was to add solidify parameters into the menu (but without the preview it
seems like people would be 'shooting in the dark').
I may try to pick 6 or 8 standout variations, and leave the option of
running it on an extracted and solidified subject or picking a preset.
PostPosted: Tue Dec 27, 2016 12:49 pm  (#10)
Wow animicule! you got the effect! I love the results. You both are a great team. ;) :bump
PostPosted: Tue Dec 27, 2016 3:22 pm  (#11)
The pumpkins came out creepy (i.e., great). lol
The fishtank looks cool too, Brian. :)
PostPosted: Wed Dec 28, 2016 9:57 am  (#12)
Thanks Lyle!
here is an example from the script as it is.
Border from new layer>select all>fill (was yellow) > shrink selection a few> invert selection>delete
and ran the script with solidify on that layer only, set to screen.
Just a little different after about 100 runs trying decide pre-select options for the solidify step.
