It is currently Thu Nov 19, 2026 7:04 pm
 Post subject: SOAP BUBBLES
PostPosted: Wed Jan 04, 2017 4:21 pm  (#1)
I am looking for soap bubbles brushes.
a while ago I had computer problems, then i reinstalled gimp but I was lost much brushes and other stuf.
so, now I'm looking for different soap bubbles brushes.
thanks in advance,gimper66
 Post subject: Re: SOAP BUBBLES
PostPosted: Wed Jan 04, 2017 4:27 pm  (#2)
Check on DeaviantArt.
I'm sure you'll find some brushes there you like.
Or look here: Free Bubble Brushes
PostPosted: Wed Jan 04, 2017 4:31 pm  (#3)
You can make them by yourself easily. Use a circle selection and the airbrush tool, than copy them as pencil, this will make a lot of fun and you get exactly the Bubbles, you like.
LG Susi
PostPosted: Wed Jan 04, 2017 5:18 pm  (#4)
Here's a single bubble brush I created from a ball bearing image a few years back. :)
Below's something I concocted using this brush (and a few other things) a few years back. :)
viewtopic.php?f=11&t=9998&hilit=bubble
bubble.gih [30.4 KiB]
Downloaded 250 times
PostPosted: Wed Jan 04, 2017 9:22 pm  (#5)
Here are some to try.
10_soapy_gimp_bubble_brushes_by_ln213.zip [281.84 KiB]
Downloaded 331 times
water_bubble_brush_for_gimp_by_ln213.zip [23.99 KiB]
Downloaded 243 times
5_soap_bubbles_abr.zip [4.83 MiB]
PostPosted: Thu Jan 05, 2017 5:24 am  (#6)
thanks everyone the soap bubbles are flying around my ears now
I needed the bubbles to make business cards for my daughter,they already runs 15 years a dogs grooming salon (I hope my translation is correct)
PostPosted: Thu Jan 05, 2017 8:10 am  (#7)
I like your design and result. The bubbles look great, too. I'm sure that your daughter will be happy for such a nice outcome. :coolthup :)
PostPosted: Thu Jan 05, 2017 3:00 pm  (#8)
Those cards are really cute. They should work fine!
PostPosted: Fri Jan 06, 2017 7:22 pm  (#9)
There is also a script available to create soap bubbles. :)
http://gimpscripts.com/2011/10/soap-bubble/
PostPosted: Fri Jan 06, 2017 11:06 pm  (#10)
viewtopic.php?f=12&t=7845
