It is currently Thu Nov 19, 2026 7:09 pm
 Post subject: Can you see it?
PostPosted: Sun Jan 08, 2017 5:31 pm  (#1)
Open the image in its own tab in your browser (or any image viewer/editor), scale it/zoom it so that the centers of the circles are physically about 60mm (2.5") apart (on regular screens (~100DPI) you can just zoom out to 66%). Then get close until you see a third object in the middle of each pair. The top one is a pit, the bottom one a pyramid.
Gimp, ofn-path-to-shape+path-inbetweener.
 Post subject: Re: Can you see it?
PostPosted: Sun Jan 08, 2017 10:27 pm  (#2)
all for look like pyramids to me.
PostPosted: Mon Jan 09, 2017 2:15 am  (#3)
You should be seeing six.
PS Make sure there isn't a candid camera behind you while trying this.
PostPosted: Mon Jan 09, 2017 3:09 am  (#4)
Of you do this properly you don't need to squint. On the contrary, keep your eyes parallel. The hard part is doing this while focusing on something close, far-sighted people with glasses have an advantage.
Over on gimp-forum.net there is a "pattern" version which may be easier for some.
