It is currently Thu Nov 19, 2026 7:09 pm
 Post subject: Transfer Colours
PostPosted: Sat Jan 28, 2017 6:44 am  (#1)
An example
2017-01-16 15-50-02 pexels-photo-58680, with colours modified using pexels-photo-62807.jpg
2017-01-16 15-50-02 pexels-photo-58680, with colours modified using pexels-photo-62807.jpg [ 149.53 KiB | Viewed 5016 times ]
 Post subject: Re: Transfer Colours
PostPosted: Sat Jan 28, 2017 6:52 am  (#2)
Another example (in this case I used an image filled with a gradient as a source for colours)
original
with transger of colours
2017-01-18 07-47-57 girl-lake-dress-white-160540, with colours modified using fog-mist-golden-sunrise-73756.jpg
2017-01-18 07-47-57 girl-lake-dress-white-160540, with colours modified using fog-mist-golden-sunrise-73756.jpg [ 125.11 KiB | Viewed 5015 times ]
PostPosted: Sat Jan 28, 2017 9:59 am  (#3)
More samples with this nice filter. :) :bigthup
PostPosted: Sat Jan 28, 2017 10:01 am  (#4)
And this. I really wanted to see how the result would be if the photo was in Black and White. :)
PostPosted: Sat Jan 28, 2017 10:12 am  (#5)
Playing a bit more.
PostPosted: Sat Jan 28, 2017 10:14 am  (#6)
and this. :)
PostPosted: Sat Jan 28, 2017 10:48 am  (#7)
Very very nice the "cristales" ! I like the result.
Thanks for all your contributions, Issabella.
To explain what happens with a B&W target: it's like using Colorize because all values are gray, i.e. same values for R,G,B
PostPosted: Sat Jan 28, 2017 10:51 am  (#8)
Thank you so much Dinasset. I now understand its behaviour on B&W, thanks for your explanation about it. :) :bigthup
PostPosted: Sat Jan 28, 2017 12:23 pm  (#9)
I did one more. :) It's magic! :hi5
PostPosted: Sat Jan 28, 2017 12:54 pm  (#10)
Nice result, Issabella !
PostPosted: Sun Jan 29, 2017 2:59 am  (#11)
Done in the morning. :)
PostPosted: Sun Jan 29, 2017 3:36 am  (#12)
nice "Good Morning" Issabella !
PostPosted: Sun Jan 29, 2017 2:56 pm  (#13)
My "Good Night"
target image
source gradient (Abstract 2)
result
2017-01-29 20-52-51 girl-380621_960_720, with colours modified using a gradient.jpg
2017-01-29 20-52-51 girl-380621_960_720, with colours modified using a gradient.jpg [ 190.21 KiB | Viewed 2308 times ]
PostPosted: Sun Jan 29, 2017 3:50 pm  (#14)
I did my transferred outcomes, too. :)
PostPosted: Sun Jan 29, 2017 3:51 pm  (#15)
And this.
PostPosted: Mon Jan 30, 2017 9:51 am  (#16)
I like this result a lot. :)
PostPosted: Mon Jan 30, 2017 10:02 am  (#17)
Same source that the previous result. :) :coolthup
PostPosted: Mon Jan 30, 2017 11:46 pm  (#18)
PostPosted: Thu Feb 02, 2017 12:12 pm  (#19)
PostPosted: Thu Feb 02, 2017 1:07 pm  (#20)
Pat, you last two transfers look good. Thanks.
Just a suggestion (for everybody, not only for you, it's a general hint):
- when you don't see enough transferral of the source colours, you may repeat the procedure, using the resulting image as target and still the same source of colours; you'll get a step forward in the transferral
