It is currently Thu Nov 19, 2026 6:21 am
Post new topic Reply to topic  [ 240 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
 Post subject: Themes to suit joined-up text
PostPosted: Sat Feb 04, 2017 3:33 pm  (#1)
Still working on script and font for joined-up text and feeling that I am getting somewhere at last. Latest font revision has as little overlap as I can manage.
Two images to illustrate the sort of uses that I originally had in mind for the script.
[thumbnail=0]Around the World.jpg[/thumbnail]
 Post subject: Re: Circular themes to suit joined-up text
PostPosted: Sat Feb 04, 2017 6:07 pm  (#2)
Hoping to see the new version of 'joined-up text' soon :coolthup
PostPosted: Sat Feb 04, 2017 10:25 pm  (#3)
This would be awesome! I've been using the text circle scripts and had to keep manually adjusting font size, spacing, etc. to try and get the ends to properly meet without overlapping. This will be awesome!!
My Sigs = My Photos
PostPosted: Sun Feb 05, 2017 4:01 pm  (#4)
Graechan and Photomaster:
I'm not getting too excited about the successful outcome here - the problem I have is with overlapping regions between letters. If the control points that form the curves/straight lines of adjoining letters are apart then, obviously, you expect a gap to be visible. If the control points overlap then this shows up when creating a path from the text and touching up is required. Also when the control points between adjoining letters are as tight as possible/just touchin/on top of each other (I've tried them all), the outcome is still not quite right. It seems that the font engine needs some overlap in order to display a gapless font on screen which is then, quite logically, faithfully reproduced in the text to path option.
When a line of text is then made to follow a circular path the letters are deformed to fit the path of the circle and the paths of individual letters can be forced closer or further apart from their neighbours. Until someone comes up with a script to force the paths of all the letters in a word into one continuous path it appears that we are stuck with touching up the joins - either by editing the paths manually or by editing a selection taken from the text path.
I was just trying to find a way to speed up this touching up process by reducing unwanted gaps/overlaps within a font.
To gap or not to gap that is the question. I'm off for a glass of wine to stop my head from hurting.
PostPosted: Tue Feb 07, 2017 5:01 am  (#5)
Almost there. Have decided on best compromise - small as possible overlap. Just need to fine tune one or two letter glyphs.
PostPosted: Tue Feb 07, 2017 9:39 am  (#6)
Waiting with baited breath for the script! Looks like you are persevering and getting there. :yes
PostPosted: Tue Feb 07, 2017 3:16 pm  (#7)
Thank you so much for your effort. I agree with Sallyanne and I'm sure you are going to get it. :bigthup :yes
PostPosted: Tue Feb 07, 2017 4:03 pm  (#8)
Your demo images are excellent! I am so looking forward to this script!!
My Sigs = My Photos
PostPosted: Tue Feb 07, 2017 4:06 pm  (#9)
Your efforts will be so rewarding Skinnyhouse, well done you :hi5
PostPosted: Thu Feb 09, 2017 3:20 pm  (#10)
I have finished (hopefully) the new version of the Joined-up script and accompanying font and uploaded it to Gimp Scripts and Plugins. Follow this link:
viewtopic.php?f=9&t=15272
The basic stages involved in making circular text are (other ways always exist in Gimp):
Type some text at 140 size (probably between 40 and 60 characters to go around a 1500 x 1500 circle) into the Joined-up Text Filter.
Create a circle selection and then use this to make a path.
Add the text to the path to create a new text path.
Make a selection from this new text path.
Add a new layer and fill the selection with colour.
Dismiss the selection and hide the path to see your new text.
I have uploaded some pdf help sheets to try and guide people through the steps involved in placing text around a circle. There is no actual finished image involved but you should be able to use these skills in your own creations. It is probably not a suitable task for a Gimp novice.
JoiningToCircleHelp.zip [598.29 KiB]
Downloaded 765 times
The lyrics to 'The Windmills of your Mind' - the title song from the 1968 film 'The Thomas Crown Affair' - has a lot of inspirational ideas for circular themes.
JoiningToCircleHelp.zip [598.27 KiB]
Downloaded 717 times
PostPosted: Thu Feb 09, 2017 7:15 pm  (#11)
This is one of my first attempts. I love the way it works and will have to try it more seriously.
(The image is a VERY old one of me with a few of my antique cameras)
My Sigs = My Photos
PostPosted: Thu Feb 09, 2017 10:28 pm  (#12)
Skinnyhouse - terrific and will prove very useful. :tyspin
PostPosted: Fri Feb 10, 2017 4:37 am  (#13)
OMG and PM:
Wow guys... you're so much quicker than me... takes me ages to be creative... such great images. What a cool collection PM!
PostPosted: Sat Feb 11, 2017 9:05 am  (#14)
Great script thank you Skinnyhouse
PostPosted: Sat Feb 11, 2017 11:42 am  (#15)
RJKD:
Great one - this could be the future - Never mind bitcoins on the tinty - let's incorporate these into the site as payment for favours done - the first gimpcoins!
PostPosted: Sat Feb 11, 2017 4:01 pm  (#16)
Spiral form seems to fit well too...
PostPosted: Sat Feb 11, 2017 11:22 pm  (#17)
Wow! That is all I can say right now. Superb!!!! I must study your instructions before I try as I confused early on. Your really did a wonderful job on this one!
PostPosted: Sun Feb 12, 2017 6:49 am  (#18)
Thank you Pat. I will take that as a huge compliment since you are always so very creative in your postings.
If you haven't used the Text to Path option before it really is quite straight-forward. I think the thing that catches most people out (certainly still does me at times) is to remember to add a new layer to stroke the path (or fill a selection of the path) into. If you forget this will be directed to the text layer that you used earlier, as it will still be the active layer, and nothing will appear to happen.
Best of luck.
PostPosted: Sun Feb 19, 2017 5:42 am  (#19)
Working on an italic joined-up font - almost there - but seems to be working quite well.
PostPosted: Sun Feb 19, 2017 7:33 am  (#20)
Great work skinnyhouse, your a good man :hi5
