It is currently Thu Nov 19, 2026 5:22 pm
 Post subject: playing with map bump and peeling paint
PostPosted: Fri Apr 21, 2017 5:30 pm  (#1)
These are kind of fun
 Post subject: Re: playing with map bump and peeling paint
PostPosted: Fri Apr 21, 2017 5:31 pm  (#2)
A hornbill on peeling paint
PostPosted: Fri Apr 21, 2017 7:08 pm  (#3)
Beautiful! I love the textures you used.
My Sigs = My Photos
PostPosted: Fri Apr 21, 2017 7:37 pm  (#4)
Great results! =)
PostPosted: Mon Apr 24, 2017 9:53 am  (#5)
Thank you Photomaster & Rod !
With a smoother background texture
PostPosted: Mon Apr 24, 2017 9:54 am  (#6)
And with a very distressed paint peel
PostPosted: Mon Apr 24, 2017 10:02 am  (#7)
Up my street - like the effects a lot.
PostPosted: Mon Apr 24, 2017 10:10 am  (#8)
:kpix Always coming up with something new.
PostPosted: Mon Apr 24, 2017 10:43 am  (#9)
Thank you Skinnyhouse and Sallyanne <-(I want to learn map it to a 'plane' and then rotate it) when I get home...
PostPosted: Mon Apr 24, 2017 11:27 am  (#10)
You will no problem :) :)
Just go to Filters > map > map object > and select 'plane' which should be the default one open.
To rotate your picture just click on the orientation tab.
PostPosted: Wed Apr 26, 2017 5:15 pm  (#11)
Thanks Sallyanne, tried it on a few things and it works good, just have to remember to have plenty of canvas or things tend to get trimmed!
PostPosted: Wed Apr 26, 2017 5:17 pm  (#12)
Slight return to the wigs.
PostPosted: Thu Apr 27, 2017 8:56 am  (#13)
Hummingbird with exaggerated distressed peeling baseboard paint
PostPosted: Mon May 01, 2017 8:43 am  (#14)
Used a piano keyboard photo instead of peeling paint on this one.
PostPosted: Tue May 02, 2017 12:38 pm  (#15)
Animicule, what is your workflow to get such clarity? Do you start with the peeled paint and bump the photo onto it, or the opposite? Do you use any other filter over it?
PostPosted: Tue May 02, 2017 1:33 pm  (#16)
Sorry Pat, I just get an idea and try
whatever it takes to get close to what
I think it should look like. It never
really turns out that way, but close enough.
I only spend about 5 minutes at it while doing
other things. It's just play.
I know I have tried mapping each to themselves,
then one to the other and then layer play
PostPosted: Tue May 02, 2017 10:31 pm  (#17)
Animicule, tried to upload an image for you to critique for me but I cannot upload at all now. Earlier today it was on & off.
PostPosted: Wed May 03, 2017 2:32 am  (#18)
I tried your technic on peeling paint. But I still can't upload the image. Thanks a lot.
PostPosted: Wed May 03, 2017 5:11 pm  (#19)
Yes, not much fun without some pictures.
I do use color mode and also the mapped images at various opacities.
I just never paid attention to what my fingers were doing.
PostPosted: Sun May 07, 2017 8:00 pm  (#20)
[url]https://www.dropbox.com/Images/awb9x9i7zyl9d1q/PeelingPaint.BumpMap.jpg?dl=0[/url]
