It is currently Thu Nov 19, 2026 5:23 pm
 Post subject: urban
PostPosted: Tue Apr 25, 2017 11:38 pm  (#1)
Took my experiment into creating fake HDRs and acidified it. lol
Basically I ran G'MIC's Cartoon preset (lowered sharpness and set edge thickness to zero) on the convolution layer and set that layer result to Grain merge. I then used a copy of the original layer, copied it on top and set to color. I did do some additional play for further simplicaton but that's the nuance stuff that's my personal secret (i.e., way too lazy to outline everything; the above steps get you quite close though). Some may like the result; others won't. Again, just an experiment. :)
ref: https://upload.wikimedia.org/wikipedia/ ... _visit.jpg
https://www.flickr.com/photos/34520999@ ... 4/sizes/o/
 Post subject: Re: urban
PostPosted: Wed Apr 26, 2017 1:53 am  (#2)
I like it lyle. And the various effects and layers have been applied democratically to the whole image. :clap
PostPosted: Wed Apr 26, 2017 3:53 am  (#3)
Exaggeration filter with convolution layer deleted and an extra multiplied layer.
PostPosted: Wed Apr 26, 2017 4:19 am  (#4)
:kpix
PostPosted: Wed Apr 26, 2017 10:31 am  (#5)
Wow! That is an amazing image! I think I must try that myself!
My Sigs = My Photos
PostPosted: Thu Apr 27, 2017 8:36 am  (#6)
I like a 2 minute blend of the 2 with more detail in the foreground (bottom of the gradient layer mask) and abstract sky quickly erased.
PostPosted: Thu Apr 27, 2017 12:50 pm  (#7)
Nice blended result, Brian. :)
