It is currently Fri Nov 20, 2026 7:32 pm
 Post subject: A little sig
PostPosted: Mon Apr 18, 2011 4:09 pm  (#1)
I made a signature and I was wondering what you guys would think of it.
Feel free to post what you think.
Come on people make some sigs for sig of the week!
 Post subject: Re: A little sig
PostPosted: Mon Apr 18, 2011 4:38 pm  (#2)
Looks great!
PostPosted: Mon Apr 18, 2011 4:52 pm  (#3)
Thank you! It is my first time using a pop out render and I was hoping I would have a positive result.
PostPosted: Mon Apr 18, 2011 5:07 pm  (#4)
Why is your name located where you have it? Wouldn't it be more viewable toward the bottom corner? Just curious, not criticizing.
PostPosted: Mon Apr 18, 2011 6:14 pm  (#5)
With Sigs, you usually would place your name near the Renders, but in this case, I would move it a bit lower and Centralized. But I suck with Text :/
I'm back I think
PostPosted: Mon Apr 18, 2011 10:28 pm  (#6)
I put it there because it is closer to the bottom middle. I just can never place text in the right place though. =/
PostPosted: Tue Apr 19, 2011 12:59 am  (#7)
Looks really cool! :)
PostPosted: Tue Apr 19, 2011 2:25 am  (#8)
Well if you are just telling people this art is mine - keep it the same size and lower to the left.
If you want it as a focal when someone first looks at the image - make it smaller and place it on a lighter background area.Like over the ray beam that's light blue.
Looks cool though.The colors flow real nice, and I love Tron. :)
PostPosted: Tue Apr 19, 2011 5:12 am  (#9)
Former Member
Looks pretty dope bro! The only improvements I recommend is fix the text, and work on getting a better effect for that force field like thing, cause it looks poor imo.
PostPosted: Tue Apr 19, 2011 4:03 pm  (#10)
That force field thing was part of the original image. I will try to fix the text.
PostPosted: Tue Apr 19, 2011 4:29 pm  (#11)
Is the text better in this one?
PostPosted: Tue Apr 19, 2011 4:35 pm  (#12)
Very nicely done! I like the new one better. The text is more readable.
My Sigs = My Photos
PostPosted: Tue Apr 19, 2011 4:51 pm  (#13)
Your the on that suggested to me that I could put the text there (I think).
Anyways, thank you!
