It is currently Thu Nov 19, 2026 5:45 pm
 Post subject: Happy Accident with GMIC
PostPosted: Thu Jun 08, 2017 8:38 pm  (#1)
I dont remember how I stumbled on this combination, but its one of my favorite effects that I use a lot
 Post subject: Re: Happy Accident with GMIC
PostPosted: Thu Jun 08, 2017 8:40 pm  (#2)
Very cool graphic!
PostPosted: Thu Jun 08, 2017 8:43 pm  (#3)
Its easy! set an image with a transparent background
Click on Dream smoothing, then >Details< Dcp Dehaze
It leaves a kind of distorted smoke look
PostPosted: Thu Jun 08, 2017 8:44 pm  (#4)
PostPosted: Thu Jun 08, 2017 11:17 pm  (#5)
Very nice results Norseman. I find happy accidents with G'MIC all the time. An extremely powerful preset/plugin for sure and it's usefulness has no ends with me. I usually use something in G'MIC for all of my edits now. :)
PostPosted: Thu Jun 08, 2017 11:46 pm  (#6)
I've always been a fan of G'MIC's Dream Smoothing filter.
When combined with the G'MIC's Dcp Dehaze filter.
You produced an excellent outcome.
PostPosted: Fri Jun 09, 2017 10:29 am  (#7)
Nice outcome! Same here, like dream smoothing, graphic boost, graphic novel and similar filters a lot.
Try out dream smoothing + graphic boost or graphic novel that's one combo I've been using.
PostPosted: Fri Jun 09, 2017 12:05 pm  (#8)
cool accident.
PostPosted: Fri Jun 09, 2017 3:32 pm  (#9)
I decided to try playing with this myself and I came up with a freaky situation. I took my seagull pix, isolated and removed the background. I copied the visible image which was only the gull. When I try running the Dream Smoothing on the image, it miraculously restored the entire image. I saved just the gull as it's own xcf file and restarted Gimp figuring that nothing would be held in cache. I reloaded the single layer image, which was just the gull and the transparent background. When I ran the Dream Smoothing filter, it again restored the entire background. What the ???. I'm going to try it again, saving a copy as a png.
My Sigs = My Photos
PostPosted: Fri Jun 09, 2017 3:40 pm  (#10)
G'mic probably doesn't use the same cache as GIMP.
Maybe try reboot the computer and run again.
If it still does it, cool to try do dreamsmooth on one image,
close it, rename another image (already isolated) to the same name
and try again. Can't wait to get home...
PostPosted: Mon Jun 12, 2017 10:24 am  (#11)
Seems to me more like when the image is cut, there still may be information
in the image file and the dreamsmoothing brings it back out to some degree.
I forgot to test to see how much if any the file size changes after being isolated,
and I don't know anything about the structure of image files.
It is not stored in cache memory... tested. Thought it would be cool if it was.
PostPosted: Mon Jun 12, 2017 2:16 pm  (#12)
I saved my cut out image as a .png file and reloaded the .png file. It worked ok then.
My Sigs = My Photos
PostPosted: Mon Jun 12, 2017 3:18 pm  (#13)
I ran one of my tests through again and got this and thought it was cool...
PostPosted: Wed Jun 14, 2017 12:02 pm  (#14)
Yah, Me too
I use GMIC almost all the time
Its funny I hardly ever use any of the filter built into Gimp
I use some of the scripts people make here, as well
PostPosted: Wed Jun 14, 2017 12:04 pm  (#15)
I like graphic novel when I want less distortion than Dream smoothing goes.
PostPosted: Wed Jun 14, 2017 12:08 pm  (#16)
I noticed that too
You have to open a whole new project
paste it in a new window
PostPosted: Wed Jun 14, 2017 12:09 pm  (#17)
