It is currently Thu Nov 19, 2026 5:23 pm
 Post subject: Shredded
PostPosted: Fri Jun 23, 2017 7:33 am  (#1)
Consider this one a work in progress. lol
https://www.flickr.com/photos/34520999@ ... 5/sizes/o/
 Post subject: Re: Shredded
PostPosted: Fri Jun 23, 2017 7:50 am  (#2)
Waiting for the ...progress, this outcome doesn't look nice at all.....ehehe
(sorry, just an instinctiv reaction of my humble opinion...)
PostPosted: Fri Jun 23, 2017 10:20 am  (#3)
I'm liking it!
My Sigs = My Photos
PostPosted: Fri Jun 23, 2017 10:05 pm  (#4)
I think i see where you are going with this. Results could be pretty fascinating. Are you adding color overlay by chance?
PostPosted: Fri Jun 23, 2017 10:27 pm  (#5)
Thanks for the comments. To answer Rod, I created a convolution layer and only applied that to the front shreds if you will. The front shreds were colorized using G'MIC's Blend>Shape Average preset under my name in Testing folder for G'MIC. Created the Shreds themselves using various passes of Stencil set to Difference to create the mask. The rear shreds were just flips of the Front and dup set to Difference (could just as well used subtract) to darken. Still, again, a work in progress. :)
PostPosted: Sun Jun 25, 2017 8:59 am  (#6)
OK; this one might be more aesthetically pleasing. lol
Took a triple layered approach this time blurring the lower layers at consecutively higher blur radius and amount. Still used the dup difference method to darken the lower layers too. :)
ref: http://www.fontplay.com/freephotos/seve ... 506-09.jpg
https://www.flickr.com/photos/34520999@ ... 6/sizes/o/
PostPosted: Sun Jun 25, 2017 11:03 am  (#7)
Lyle, I like the effect if you see it from a distance, it is even nicer. :bigthup
PostPosted: Sun Jun 25, 2017 10:13 pm  (#8)
Thanks, Issabella. Still, a work in progress. Have some other ideas but am too tired to try them at the moment. :)
PostPosted: Mon Jun 26, 2017 6:30 am  (#9)
I like them both as Issabella stated you look from way back and they really stand out. =)
PostPosted: Mon Jun 26, 2017 10:25 pm  (#10)
Thanks, Rod and all that commented. Probably going to give up on this short lived binge since I cannot get the details that I want out and just cannot seem to figure out a good method to do so. :)
