It is currently Thu Nov 19, 2026 4:31 pm
 Post subject: Gear
PostPosted: Mon Jun 26, 2017 8:04 am  (#1)
Don't spend a lot of time with bump mapping but did this recently
Using Graechan's Path Shape creator, mh3Dbevel, a gradient, light and shadow - lighting effects bump map (not necessarily in that order) I got this
 Post subject: Re: Gear
PostPosted: Mon Jun 26, 2017 6:55 pm  (#2)
Interesting effect sallyanne and nicely done...
PostPosted: Mon Jun 26, 2017 7:18 pm  (#3)
Sweet! That came out nicely!
My Sigs = My Photos
PostPosted: Tue Jun 27, 2017 2:03 am  (#4)
Thanks racer and PM.
Today I tried a spring
PostPosted: Wed Jun 28, 2017 10:31 am  (#5)
PostPosted: Thu Jun 29, 2017 11:59 pm  (#6)
Sallyanne, Those images are all very nice, and pretty. Nice work. Your expertise is showing.
PostPosted: Fri Jun 30, 2017 12:25 am  (#7)
Sallyanne,
your last creations are excellent, congrats!
PostPosted: Fri Jun 30, 2017 1:38 am  (#8)
:clap Sallyanne, your two last outcomes are really good. I love the spiral metallic one.
PostPosted: Fri Jun 30, 2017 2:42 am  (#9)
Thank you Pat, dinasset and Issabella. I was quite pleased with the spring too.
Flowers are a work in progress though. I was quite surprised how the leaf layer turned out. I just used a leaf brush and some of them were less opaque than the others and you can still see them.
Still very much behind many people and probably always will be.
PostPosted: Wed Jul 05, 2017 10:50 pm  (#10)
Had a couple of days of the internet (forced) and still could not think of much to do. So I messed around with a "Drop" from 'path shape creator' and came up with these
PostPosted: Thu Jul 06, 2017 9:31 am  (#11)
That's the beauty of Gimp. With so many options you are ahead of some people and behind others in different areas. I know I'm behind in many areas because I'm learning new things every day. You've taught me a few things too! Your work is amazing!
My Sigs = My Photos
PostPosted: Thu Jul 06, 2017 7:54 pm  (#12)
I too am well behind most people using Gimp. I've only started using it recently, but I've been editing photos and video for years. I'm quickly learning how to use Gimp to get the results I want.
I just now figured out a way to make decent engraving-carving effect...
PostPosted: Thu Jul 06, 2017 8:00 pm  (#13)
Love the engraving.
My Sigs = My Photos
PostPosted: Mon Jul 10, 2017 3:09 pm  (#14)
:coolthup racer
PostPosted: Tue Jul 11, 2017 8:03 am  (#15)
Hi racer-x,
I watched this vid:
https://www.youtube.com/watch?v=p1K3L7RdbKw
I found that select > invert and then drop shadow works because it's shading the inside rather than the outside of the engraved object. I think 'engraved' is below the surface and 'embossed' is above the surface.
