It is currently Thu Nov 19, 2026 7:45 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Face painting
PostPosted: Thu Aug 17, 2017 7:13 am  (#1)
I'm concentrating on face painting, here are my first couple of attempts, I'm now focusing on hair and getting that somewhat ok.
 Post subject: Re: Face painting
PostPosted: Thu Aug 17, 2017 8:21 am  (#2)
...go on ! It seems you found a good technique.
My suggestion: now improve the hair aspect, it has a lot of relevance on "framing" the face.
PostPosted: Thu Aug 17, 2017 11:39 am  (#3)
Thankyou dinasset, Erisian made a great tutorial. I've found a really good photoshop tutorial for hair and I'm attempting to create the same effect with Gimp. Getting the exact correct brush for the path strokes is the key I think.
https://www.youtube.com/watch?v=WNXV2FAmK-s
PostPosted: Thu Aug 17, 2017 5:03 pm  (#4)
Sweet! Plus I love redheads!
My Sigs = My Photos
PostPosted: Wed Aug 23, 2017 1:29 pm  (#5)
Getting closer to a half decent hair brush...
PostPosted: Wed Aug 23, 2017 2:16 pm  (#6)
I find your work to be very good, RJKD. :clap :hi5
PostPosted: Thu Aug 24, 2017 12:12 am  (#7)
I don't know whether you like to use only the painting technique or accept to use other Gimp capabilities.
In the latter, just applying more contrast on the head could improve the result a step further.
Example:
You're on the right track.
PostPosted: Thu Aug 24, 2017 12:42 am  (#8)
Here I applied brightness/contrast on the whole image (simpler..., a bit different result)
PostPosted: Thu Aug 24, 2017 5:58 am  (#9)
Thankyou PhotoMaster, Issabella and dinasset, your encouragement motivates me.
I hadn't given any thought to overall tweaking of the image dinasset, I really like the outcome of "plus contrast", something to consider, thankyou.
PostPosted: Thu Aug 24, 2017 11:11 pm  (#10)
I am amazed at your progress in such a short period of time!! I don't think I could ever do that. Be proud!!
PostPosted: Sat Aug 26, 2017 5:00 am  (#11)
Thankyou Pat, your encouragement is really appreciated.
PostPosted: Fri Sep 01, 2017 10:56 am  (#12)
My 4th head, the head gear is a cut out.
PostPosted: Fri Sep 01, 2017 5:54 pm  (#13)
I really like the way you shaded and accented his hair and beard!
PostPosted: Thu Sep 21, 2017 7:40 am  (#14)
Head4
PostPosted: Mon Sep 25, 2017 4:22 am  (#15)
You are doing some amazing work here RJKD. The lips on the last one are really realistic - any tips for me? I really hope you do more of these faces as you are improving rapidly. :bigthup :coolthup
PostPosted: Mon Sep 25, 2017 12:18 pm  (#16)
High praise coming from you Erisian, thank you for your encouragement. I use a lot of Gaussian blur. One aspect I'm struggling to nail is getting a blend from the lips to the skin, for me they still look 'stuck on'. My go to reference is your excellent tutorials... :tyspin
viewtopic.php?f=23&t=7053
 Post subject: Re: Face , painting
PostPosted: Mon Sep 25, 2017 2:20 pm  (#17)
You are doing a wonderful job, RJKD. Keep on! OH, Yes, Erisian is a good teacher. I always enjoy his creations and wish he could participate more. But then, I know myself that life often gets in the way.
PostPosted: Tue Sep 26, 2017 2:47 am  (#18)
I enjoy seeing your quick progress, RJKD. Your results are very good and I know you will reach your aim very soon. :yes
PostPosted: Tue Sep 26, 2017 4:12 am  (#19)
The wide shadow under the lips goes too far around. If you try keeping it to the middle you may find your lips look more a part of the face.
PostPosted: Tue Sep 26, 2017 9:08 am  (#20)
RJKD, While looking at your painting, I noticed that her Rt. Eyelashes are much shorter than the Lt ! She is a beauty anyway!
