It is currently Thu Nov 19, 2026 4:27 pm
 Post subject: Doll dots.
PostPosted: Tue Sep 19, 2017 5:32 am  (#1)
ref: http://www.fontplay.com/freephotos/seve ... 107-03.jpg
Not the first time I used this doll model for rendering even similar things, but just showing that I'm inching ever close to the elusive Ben Stein result (automated). :)
 Post subject: Re: Doll dots.
PostPosted: Tue Sep 19, 2017 5:41 am  (#2)
As a side note, I used the result below along with convolution enhancement (this example has no CE applied) for the mask. Thought worth sharing since it's sort of a new way to engrave. :)
PostPosted: Tue Sep 19, 2017 8:47 am  (#3)
Both came out great. I especially love the dots as stippling is one of my favorite techniques.
My Sigs = My Photos
PostPosted: Tue Sep 19, 2017 11:05 am  (#4)
Thanks Greg. The reason why the dots don't follow the black striped lines is I invert the image for the mask before feeding it into VS. I then invert the dots (white dots) which G'MIC's Blend (Shape Average) likes to colorfy the dots (original as the source color). :)
PostPosted: Tue Sep 19, 2017 11:49 am  (#5)
Thought I would do a re-do and present the dots as artificial pearls. :)
https://www.flickr.com/photos/34520999@ ... 1/sizes/o/
PostPosted: Tue Sep 19, 2017 11:56 am  (#6)
The pearls are amazing! I must try to duplicate the effect!
I would love to see the steps outlined in order, a tutorial maybe??
My Sigs = My Photos
PostPosted: Tue Sep 19, 2017 12:04 pm  (#7)
Sorry Greg, but I do have to now keep my secrets (i.e., way too lazy to do yet another tut. lol). Did sort of outline a flow here. Even so, I modified the G'MIC preset for Halftone Shapes to get a higher resolution (10 is way too large and I didn't want to have to downsize a target after running the preset). Also used G'MIC Pen to blend the halftone result into the lines as I showed earlier for masking. :)
PostPosted: Tue Sep 19, 2017 12:34 pm  (#8)
The 'pearl' version is pretty amazing, but dolly is still scary, lol.
PostPosted: Tue Sep 19, 2017 12:38 pm  (#9)
Thanks, 2-ton. I like using the same reference images so folk know that it's me doing the rendering and not someone else's render. I don't actually have to do this, of course, but it's my shtick.
As for the shading (pearl texture) I used G'MIC's Local Orientation preset for that (and a few other things). :)
PostPosted: Tue Sep 19, 2017 3:48 pm  (#10)
Tried following, but I'm just not getting it.
My Sigs = My Photos
PostPosted: Tue Sep 19, 2017 11:35 pm  (#11)
What step are you having the issue with, Greg? :)
