It is currently Thu Nov 19, 2026 4:31 pm
 Post subject: Textured effect
PostPosted: Tue Oct 24, 2017 3:33 am  (#1)
I was playing around with various Gmic filters and stumbled onto something interesting. I used "Local Orientation" filter on a duplicate layer and played with blending modes. I think it looks interesting on this shot anyway...
 Post subject: Re: Textured effect
PostPosted: Tue Oct 24, 2017 3:50 am  (#2)
Wish someone would port the "Laplacian Pyramid Filter" to gimp. It is just an outstanding filter with lots of range...
PostPosted: Tue Oct 24, 2017 6:25 am  (#3)
I like that effect racer-x.
Maybe you will like G'MIC>Testing>Naggobot>Dodge sketch (with color on)
You can combine layers with more color with the result from "Dodge sketch" filter.
Also there is Iain Fergussons "Pyramid processing" filter: G'MIC>Testing>Iain fergusson>Pyramid processing
That filter does't process contrast, gamma satuaration etcetera (as in the filter you described above, from Michael Vinther http://meesoft.logicnet.dk/ ), so you have to do that kind of filtering after or before the editing with the "Pyramid processing" filter.
And there is the "Tone enhance" filter: G'MIC>Details>Tone enhance (by Garagecoder)
You can get much color with the "DCP dehaze" filter: G'MIC>Details>DCP dehaze
After that you can smooth the result with a smoothing/blurring filter you prefer.
Little playing here:
PostPosted: Tue Oct 24, 2017 10:53 am  (#4)
The "Dodge sketch" filter gives a too much metal/emboss effect.
Easier:
- Use the G'MIC "Pyramid processing" filter
- Duplicate layer
- Set Layer/blending mode to "burn" or "multiply"
- Use opacity slider
- Repeat this process if necessary
- Amplify this result with G'MIC "Tone enhance" filter
- Smooth
I'm also curious. So if you find a solution with GIMP and G'MIC, please let us know.
But you can always use "ShellOut" of course. ;)
PostPosted: Tue Oct 24, 2017 7:34 pm  (#5)
Thanks for the tip on the "Pyramid processing" filter. I never tried it before, but it works OK. I saved it in my FAVs section along with other filters I like. I'm sure I'll use it now and then to bring out shadow detail.
PostPosted: Wed Oct 25, 2017 6:34 am  (#6)
Experimenting (Gimp only).
Eagle_Flight_1080 Texture Sharpening effect high strength.jpg [ 720.68 KiB | Viewed 3746 times ]
