It is currently Thu Nov 19, 2026 4:28 pm
 Post subject: Covered bridge.
PostPosted: Mon Dec 04, 2017 12:16 am  (#1)
Posted a few examples at FM's site of a new process I concocted that I call Metallic Paper look (another HDR like result). I attached a reduced sized XCF so you can see my flow (not going to make a tute; flow should help).
You will need the luma invert script-fu. :)
ref: https://pixabay.com/en/covered-bridge-w ... w-630242/#
covered-bridge-630242_1920.7z [765.87 KiB]
Downloaded 100 times
 Post subject: Re: Covered bridge.
PostPosted: Mon Dec 04, 2017 2:42 am  (#2)
Nice... I can't see a covered bridge without thinking about this.
PostPosted: Mon Dec 04, 2017 2:59 am  (#3)
Certainly is an iconic feature of the U.S.
PostPosted: Mon Dec 04, 2017 4:33 am  (#4)
That original image was already processed. See what you can do with this covered bridge (resized down) as shot from my camera...
PostPosted: Mon Dec 04, 2017 4:56 am  (#5)
Here is my quick results using Gmic's Pyramid + Vivid filters, with blending mode set to "lighten only".
PostPosted: Mon Dec 04, 2017 7:09 am  (#6)
Like the pyramid version, racer-x. The technique that I've deployed essentially flattens depth (not to mention some edge artifacts that needs smudging and color artifacts that needed to be re-colored back to normal (unless you like purple telephone poles; lol); still working the kinks); the method you showed has more depth. Regardless. to each his/her own. :)
