It is currently Thu Nov 19, 2026 9:24 am
Post new topic Reply to topic  [ 178 posts ]  Go to page 1, 2, 3, 4, 5 ... 9  Next
 Post subject: my plays 2018
PostPosted: Wed Jan 03, 2018 7:53 am  (#1)
I decided to start a new thread, not to have a looong sequel of posts in the previous one (my plays).
I started from a NatGeo photo and played with it.
Here the original:
First play:
2018-01-03 13-12-52, DQx77qwVQAA_At6, Painted! look 1.jpg [ 313.45 KiB | Viewed 7766 times ]
Second play:
2018-01-03 13-23-34, DQx77qwVQAA_At6, Sketched and Painted! (look 2).jpg [ 309.57 KiB | Viewed 7766 times ]
(continuing)
 Post subject: Re: my plays 2018
PostPosted: Wed Jan 03, 2018 7:55 am  (#2)
Third play:
2018-01-03 13-30-23, DQx77qwVQAA_At6, with 4 supernovas!.jpg [ 392.02 KiB | Viewed 7765 times ]
Fourth play:
2018-01-03 13-42-50, DQx77qwVQAA_At6, no changes on luma, low strength, as a Colored Drawing.jpg
2018-01-03 13-42-50, DQx77qwVQAA_At6, no changes on luma, low strength, as a Colored Drawing.jpg [ 420.97 KiB | Viewed 7765 times ]
that's it.
PostPosted: Wed Jan 03, 2018 8:24 am  (#3)
Good! It's brilliant Dinasset. Your different looks on the same photo are really great! I like them. :coolthup
PostPosted: Wed Jan 03, 2018 8:31 am  (#4)
Thanks, my friend.
All the plays done using the last experimental gimp 2.9.9 by samj.
PS. not bad at all your play using my last 2017 style, the photo is suitable for many plays.
NatGeo releases very nice photos.
PostPosted: Wed Jan 03, 2018 1:29 pm  (#5)
Thank you Dinasset. I enjoy your many filters you have created and the nice results they always produce. :yes
PostPosted: Thu Jan 04, 2018 7:39 am  (#6)
As said in my first post, I'm a bit playing with gimp 2.9.9 samj edition.
Hence I decided to take my filter LookAtAllModes created for gimp 2.8 and modify it to be able to show the new set of modes, which are 64 (!) on gimp 2.9.9.
Here the outcome, if someone is interested:
The input was:
- an image as BG
- a gradient as FG at 50% opacity.
Beware, some modes did abend, hence I replaced them with NORMAL_MODE.
So, ignore the modes number: 2, 22, 29, 61, 62, 63
PostPosted: Thu Jan 04, 2018 1:47 pm  (#7)
Dinasset, thank you so much for your effort to get all possible looks on the same picture. Some of the results are really good. :yes :tyspin
PostPosted: Thu Jan 04, 2018 8:40 pm  (#8)
Dinasset, you have been very busy since the New Year! I agree with Issabella. I like most of the outcomes on such nice photos. You have great ideas.
PostPosted: Fri Jan 05, 2018 1:02 am  (#9)
Thanks Pat.
I'm a bit experimenting on 2.9.9
As we know, up to 2.8 gimp has an "error" in the implementation of modes "overlay" and "softlight", in the sense that they produce identical results.
In 2.9 they now differ.
This is a test, using the well used method of:
- duplicating the layer.
- setting mode to softlight/overlay
- duplicating again
- inverting values
This produces a (usually nice) improvement of colours.
For the test I left opacity to 100%, when using the method in the real photo manipulation we normally adjust it to lower values, but using 100% let the differences be more evident.
So, let's go and see.
Original photo:
Using overlay on both dup layers:
amber-GettyImages-527467340-540x700-overlay-valueinvert-overlay.jpg [ 167.47 KiB | Viewed 7684 times ]
Using softlight on both dup layers:
amber-GettyImages-527467340-540x700-softlight-valueinvert-softlight.jpg [ 141.17 KiB | Viewed 7684 times ]
a very big difference!
PostPosted: Fri Jan 05, 2018 1:05 am  (#10)
We may also mix up the modes.
Using overlay on first dup then softlight on second dup:
amber-GettyImages-527467340-540x700-overlay-valueinvert-softlight.jpg [ 155.56 KiB | Viewed 7684 times ]
Using softlight on first dup then overlay on second dup:
amber-GettyImages-527467340-540x700-softlight-valueinvert-overlay.jpg [ 153.14 KiB | Viewed 7684 times ]
Again a big difference.
PostPosted: Fri Jan 05, 2018 1:59 am  (#11)
Hi Diego.
Do You plan (and if YES - when) to publish your revised plugins for Gimp 2.9?
I'm not using version 2.8.22 anymore, and not all of Your plugins are easily adjusted to 2.9 - so I'm very interestednew ones with Your own versions.
PostPosted: Fri Jan 05, 2018 2:09 am  (#12)
Thanks for your interest.
Yes, I'm planning to do that.
Likely starting from my last ones published on Gimp Script & Plug-ins.
If you have any special interest on some of them, please tell me, I can start from them.
PostPosted: Fri Jan 05, 2018 2:27 am  (#13)
Thank You for the nice information.
I like all of the ARTISTIC series but my favorite is:
WireframeMap, Mosaic_Stained_Glass, AutoHatch.
PostPosted: Fri Jan 05, 2018 2:34 am  (#14)
OK, I'll start from them, likely this afternoon.
Thanks for your indications.
PostPosted: Fri Jan 05, 2018 2:39 am  (#15)
Dinasset, thank you so much for your experimentation work. :clap :tyspin
PostPosted: Fri Jan 05, 2018 3:22 am  (#16)
Thank You very much in advance.
I also use the latest version of Samj "Version de développement Gimp 2.9.9 Portable 32 bits and 64 bits Windows 2018 01 03" so Your new versions should work very well
But generally there is a problem with Python in the GCC version (it does not always work, for example: IndexprintDevelopment, autosave, Line border 2, Gimpscripter, numpyops) - so I always create a second version of Python MSC (very ugly patched with old versions of libgimp-2.0-0. dll and libgimpui-2.0-0.dll).
ps.I would like Samj to return to the Python MSC version where it is easy to add additional libraries (exiv, numpy, scipy and others) and in the GGC version it is very difficult.
PostPosted: Sun Aug 26, 2018 11:50 pm  (#17)
Quite a lot I didn't post a play here.
A new one (playing with borders inward)
2018-08-27 06-41-01 abandoned-italian-villages-07, with repeated multicoloured inward borders.jpg
2018-08-27 06-41-01 abandoned-italian-villages-07, with repeated multicoloured inward borders.jpg [ 1.43 MiB | Viewed 2056 times ]
PostPosted: Mon Aug 27, 2018 1:04 am  (#18)
That seems interesting. Is it available to test?
PostPosted: Mon Aug 27, 2018 5:45 am  (#19)
Yes, Pat, it's available for testing.
Anyone who wants to test it should:
- run gimp 2.10 (my environment has samj's 2.10.6)
- be a gimpchat member
- send me a GC PM with the e-mail address where to ship the filter
- be willing to share results and comments on GC
In your case, you meet all those "prerequisites", hence have a look at your e-mail.
Hope it works properly.
PostPosted: Mon Aug 27, 2018 7:32 am  (#20)
This new filter is cool! I like the result a lot. I'll experiment it, too. Thanks a lot. :tyspin :bigthup
