It is currently Thu Nov 19, 2026 3:04 pm
 Post subject: Glass text
PostPosted: Tue Mar 13, 2018 7:09 pm  (#1)
I made this glass text today and thought I would share.
 Post subject: Re: Glass text
PostPosted: Tue Mar 13, 2018 7:51 pm  (#2)
Nice racer-x. :bigthup
PostPosted: Wed Mar 14, 2018 1:20 am  (#3)
Really nice! :bigthup
PostPosted: Wed Mar 14, 2018 3:04 am  (#4)
Racer, I like your glass text. Glass has always so an attractive look. :bigthup
PostPosted: Wed Mar 14, 2018 4:13 am  (#5)
Hi racer.
You are getting very good at e-maps. I like the chrome and the glass text.
PostPosted: Wed Mar 14, 2018 11:37 am  (#6)
Racer, your glass text is magnificent. Will you share how you made it?
PostPosted: Wed Mar 14, 2018 5:27 pm  (#7)
It's not too difficult to make. You'll need the Bevel Reflect Logo filter. I made a Screen Cap video on doing it. Make sure to right-click on text layer to add a stroke. Be sure to select gradient on the stroke. When done with stroke, move it below the text layer and duplicate as needed. After merging the layers, you can add a drop shadow if you'd like.
Here is the E-map I used:
Here is the video tut:
Glass_Text_tut.mp4.7z [5.56 MiB]
Downloaded 663 times
Have fun...
PostPosted: Thu Mar 15, 2018 12:39 am  (#8)
Racer, thank you for your nice instructions and video! I am always looking for ways to do glass. Thanks again. I'll practice some more with this.
PostPosted: Thu Mar 15, 2018 3:44 am  (#9)
Great result Pat. If you want to smooth out the edges, I've found that the anti-alias filter in G'mic works great. I'll run it a couple of times to smooth out the edge lines.
PostPosted: Thu Mar 15, 2018 4:26 am  (#10)
Thanks for recording a great tutorial.
PostPosted: Fri Mar 16, 2018 5:11 am  (#11)
Nice work racer - now for some background distortion. Have a look at step 9 here: http://gimpchat.com/viewtopic.php?f=23&t=5126&hilit=erisian+glass+text#p63989 :)
PostPosted: Fri Mar 16, 2018 8:06 am  (#12)
Thanks for the tutorial, racer-x.
My outcome with the distortion out of Erisan's tut.
PostPosted: Fri Mar 16, 2018 9:41 am  (#13)
Ella, I like your result in combination. Well done! :coolthup
PostPosted: Fri Mar 16, 2018 9:43 am  (#14)
Thank you, Issabella. The clover for Saint-Patrick's day tomorrow :)
PostPosted: Fri Mar 16, 2018 4:44 pm  (#15)
Great idea about the distortion effect. I thought about that as well, just didn't get around to doing it yet. Here are my examples with distortion.
PostPosted: Fri Mar 16, 2018 5:02 pm  (#16)
Another way to create distortion, is to duplicate the background layer, then enlarge that layer. Then add a mask to the top layer and use your original text as the template for the mask.
Example:
PostPosted: Fri Mar 16, 2018 5:07 pm  (#17)
Example:
I'd like to see just the text and the effect that this image behind it has produced?
Edit: Hey Racer-X,
What's that font ?
PostPosted: Fri Mar 16, 2018 5:17 pm  (#18)
You mean this?
PostPosted: Fri Mar 16, 2018 5:20 pm  (#19)
racer-x wrote:
You mean this?
Yes,
exactly!
Is the font,
Bitstream Charter Bold and can you post it?
PostPosted: Fri Mar 16, 2018 5:27 pm  (#20)
It is Bitstream Charter Bold and it came with my Linux distro. I can't find the font, so can't post it.
