It is currently Thu Nov 19, 2026 3:02 pm
 Post subject: Scorpion Rattan
PostPosted: Mon Mar 26, 2018 1:21 am  (#1)
ref: https://openclipart.org/detail/23566/scorpion
Experimenting with pattern blending applying to the ribbon technique. :)
 Post subject: Re: Scorpion Rattan
PostPosted: Mon Mar 26, 2018 1:52 am  (#2)
Lyle, how interesting results with your current binge. Good!!!!! :yes :coolthup
PostPosted: Mon Mar 26, 2018 8:01 am  (#3)
Thanks Issabella. If it weren't for the multiple runs of Contours>Gradient Norm with various slide settings and also resizing followed by doing the same, I would do a tutorial, but it's the majority of these renders is nuance. Add texture patterning and blending with anisotrophic smoothing followed by more Contour>Gradient Norm, and, well, to much is too much. lololol
PostPosted: Mon Mar 26, 2018 9:01 am  (#4)
You're right Lyle, I started reading your manipulation of the image and I was already lost. :hehe
But continue experimenting and sharing your results with us. :tyspin :hi5
