It is currently Thu Nov 19, 2026 3:02 pm
 Post subject: Ripple Weave Wicker Rose
PostPosted: Mon Apr 09, 2018 12:37 am  (#1)
ref: http://www.fontplay.com/freephotos/seve ... 406-03.jpg
Used triangular ripple distortion to get this particular weave effect. Yes; still having fun. lol
https://www.flickr.com/photos/34520999@ ... 0/sizes/o/
 Post subject: Re: Ripple Weave Wicker Rose
PostPosted: Mon Apr 09, 2018 4:31 am  (#2)
My goodness, that's incredible! have you created a tutorial on this effect anywhere? Sorry if you have and I've missed it.
PostPosted: Mon Apr 09, 2018 7:04 am  (#3)
Didn't use the distortion technique or the x/2, y/2 per the tut that I outlined, but pretty much followed the flow otherwise using Ripple (triangle) distortion instead. :)
viewtopic.php?f=10&t=16370
PostPosted: Mon Apr 09, 2018 7:33 am  (#4)
Thought I would do both horizontal and vertical ripple distortion this time (didn't resize, though). Also added simple image overlay to get some added contrast (re-colorized of course for the canvas color). Well; I suppose I should call this one burlap weave. lol
PostPosted: Mon Apr 09, 2018 10:02 am  (#5)
Wow, that really looks woven!
PostPosted: Tue Apr 10, 2018 12:06 am  (#6)
Appreciate the words, 2-ton. :)
PostPosted: Sat Apr 14, 2018 9:48 pm  (#7)
Lyle, I really love those roses!
PostPosted: Sat Apr 14, 2018 9:56 pm  (#8)
Thanks, Pat. :)
PostPosted: Sun Apr 15, 2018 5:37 pm  (#9)
Lyle, would you please get a little more specific for me? When do you use the Ripple effect and what are the settings. Do you leave out any of the settings in the Wicker script? I have tried a couple different ways but cannot achieve what you have done. Also, when and how do you do your coloring?
PostPosted: Sun Apr 15, 2018 11:02 pm  (#10)
OK, Pat. What I do is first run Ripple (by the way, samj placed a better ripple in folder for g'mic; takes care of edge issues so I highly recommend using her preset), then I rotate 90 degs and run Ripple with same settings. I then run super pixel, horizontally flip and run Ripple again (same settings), then horizontally flip and rotate -90 degs to right the image and and horizontally flip and run Ripple again and then horizontally flip to recover. Sounds complicated, I know, but it's not that hard. Now with this result, I run the wicker process as I outlined. :)
PostPosted: Mon Apr 16, 2018 10:42 pm  (#11)
Lyle, this is as close to yours as I have been able to get. I have followed your instructions and even did the convolution step. Are there some changes in the default settings I should make? It does not have the "woven" look as it gets away from the center of the rose. I apologize for being such a pest but I really love this effect and would like to be able to do it.
PostPosted: Mon Apr 16, 2018 11:33 pm  (#12)
Your result actually really looks like a wicker basket, Pat. Fantastic.
As for woven look, after the reverse distortion step (don't reverse until you run superpixel first), you need to run Anisotrophic smoothing (not too smudgely, so increase sharpness) and then run Gradient norm. This gives the woven look. :)
PostPosted: Mon Apr 16, 2018 11:35 pm  (#13)
OK, Pat. Here's the steps used graphically.
ref: http://www.fontplay.com/freephotos/fift ... 606-24.jpg
Step one:
Step two:
Step three:
PostPosted: Mon Apr 16, 2018 11:39 pm  (#14)
Now recover image by reversing the ripple steps (horizontal flip, ripple, horizontal flip, rotate back, horizontal flip, ripple horizontle flip; way too may steps to create screen captures but you can figure this out).
Now run Anisotrophic smoothing:
Result so far:
Gradient Norm step:
PostPosted: Mon Apr 16, 2018 11:40 pm  (#15)
Result (no auto-level, colorize; just after the gradient norm step):
PostPosted: Tue Apr 17, 2018 8:23 pm  (#16)
Lyle, thank you very much for all of your help and instructions. I know you are busy and I really appreciate all your time and effort. I am re reading everything again and studying your screenshots so hopefully my next attempt will be better. Thanks again!
PostPosted: Tue Apr 17, 2018 10:15 pm  (#17)
Lyle! Thank you, Thank you, Thank you, Thank you!!! :yes :tyspin
I finally got that Wicker Rose! Thank you for the great instructions. It could never be as good as yours, but I am happy with it. Thanks again!
PostPosted: Tue Apr 17, 2018 10:33 pm  (#18)
Looks fantastic to me, Pat. :)
PostPosted: Fri Apr 20, 2018 9:37 pm  (#19)
Lyle, you really have me hooked on the Wicker effect! Now, I am on a binge! Oh, well, I am having fun.
PostPosted: Fri Apr 20, 2018 9:57 pm  (#20)
Definitely addicting, Pat. lolol
Result looks fantastic I might add. If you discover any additional tweaks, feel free to share too. :)
