It is currently Thu Nov 19, 2026 2:41 pm
 Post subject: Ghost story of Trolls
PostPosted: Sat May 26, 2018 6:35 pm  (#1)
(click for bigger DA version)
"Get comfortable and let me tell you a spooky story ..."
Done for a greeting card; sketched on tablet, cleanup in Krita & Gimp.
Griatch
 Post subject: Re: Ghost story of Trolls
PostPosted: Sat May 26, 2018 7:45 pm  (#2)
:coolthup :paint
PostPosted: Sat May 26, 2018 9:05 pm  (#3)
Your artwork is always awesome Griatch. Enjoy your backstories too. :)
PostPosted: Sun May 27, 2018 12:02 am  (#4)
Excellent artwork, Griatch, especially in the light/shadow implementation.
PostPosted: Sun May 27, 2018 8:16 am  (#5)
The on-duty geometry nazi thinks the shadow of the nails is a bit too low (and a bit too sharp given the relative size of the light source) :) Nice face...
PostPosted: Sun May 27, 2018 10:06 am  (#6)
At risk of repeating myself about your work, I think this is fantastic. Agree with Ofnuts about the shadow though.
PostPosted: Mon May 28, 2018 1:50 am  (#7)
Thanks for the comments!
Thanks! This backstory was on the shorter side but in an earlier version her grin had an almost wicked quality to it that really felt like a ghost story. I changed the mouth later but the overal feel of a spooky story remained.
Thanks, it's fun experimenting with light.
Yeah, I put in the glowing light orb-thing last and it ended up a bit lower in her hands than I planned for the shadows; they should really be a bit further up on her chest. Not sure about the sharpness, but I think you have a point there, I did a quick raytracing test using a sun-like light source (parallel rays), but the shadow with have a different quality as it ended up being a spherical, local light source instead (diverging rays). Thanks for the feedback, I'll try taking a second pass on the hand-shadows.
Thanks! I might go back to tweak that shadow a bit. :)
Griatch
