It is currently Thu Nov 19, 2026 2:37 pm
 Post subject: a simple "translucent" look
PostPosted: Thu Jun 14, 2018 12:53 am  (#1)
Just to play.
Open your base image.
Open the image you like to see appearing "translucent" on the base (should have darks around)
Copy the second one as a layer on top of the base.
Add a mask "grayscale copy"
You did it.
 Post subject: Re: a simple "translucent" look
PostPosted: Thu Jun 14, 2018 11:27 am  (#2)
Thank you so much for this play, Dinasset. I'd have never guessed to do this translucent effect, as it's the first time I use grey layer mask. :) :coolthup
PostPosted: Thu Jun 14, 2018 1:48 pm  (#3)
Very nice !
Easy technique, isnt'it?
PostPosted: Fri Jun 15, 2018 9:33 am  (#4)
Cool :bigthup . Added some extra lightning
PostPosted: Sat Jun 16, 2018 1:38 am  (#5)
Nice result, Sallyanne. ;) :bigthup
PostPosted: Thu Jun 21, 2018 10:31 am  (#6)
A play to recall...
PostPosted: Thu Jun 21, 2018 10:41 am  (#7)
...and
PostPosted: Thu Jun 21, 2018 4:03 pm  (#8)
Diego - a neat, simple trick; thank you.
PostPosted: Thu Jun 21, 2018 11:14 pm  (#9)
Thanks OMG.
Yes, very simple (discovered by chance).
PostPosted: Wed Jul 04, 2018 4:39 pm  (#10)
The best ideas start as "accidents". :)
